Transmission & Drivetrain Gearboxes, Differentials, Clutches
ys1 countershaft s/ring
Old Feb 28, 2009 | 10:45 AM
aWeimaraner's Avatar
Default ys1 countershaft s/ring
Ok so can you guys give me some advice on how to get the snap ring located at the end of the countershaft to fit(Tranny is a from a b18a ys1)?? Do you slide it into the housing itself(when I do this the bearing get stuck on the snap ring instead of passing over it), or do you place it on the top ball bearing and then try and slide the housing over it(wont fit)?? Im not sure were to put the snap ring. Just need a little direction, or possibly a new snap ring, this one is a little distorted.
Old Feb 28, 2009 | 01:06 PM
4g hatch's Avatar
Default Re: ys1 countershaft s/ring
some can be stuborn especially if you have distorted them. are you spreading the ring completly?then give the top of the case some taps with a rubber or plastic mallet.
Old Feb 28, 2009 | 04:28 PM
I was giving it some good "taps" lol. Before you put the cases together do you put the snap ring on the top bearing of the counter shaft or do you put it in the actual casing. This may seem kinda dumb but could you explain exactly what you do? Thanks
Old Feb 28, 2009 | 10:32 PM
Mista Bone's Avatar
D Tranny Guru
that ring is fine, just needs spread while dropping the case on.
Old Feb 28, 2009 | 10:54 PM
vteczone's Avatar
leave the snap ring in the casing. i dont know how the actual qualified honda tech does it but here is how i did mine..just put the case over..before u spread the snap ring, tap the case until u visually see the snap ring touches the bearing,then spread the ring..and while u spread it,tap the case until the snap ring slide thru the bearing.
Old Mar 2, 2009 | 08:17 AM
ooo good stuff thanks guys, i just need to pick up the tool and im good.
Old Mar 2, 2009 | 10:20 AM
4g hatch's Avatar
i use 2 screw drivers but it takes some talent,LOL!!!
Old Mar 3, 2009 | 12:00 PM
FishaCrx's Avatar
Ive used 2 butter knifes from the kitchen. One was dirty and even had peanut butter on it. Didnt take any skill at all just 2 mins of time. True Story.
Old Mar 5, 2009 | 07:26 PM
4g hatch's Avatar
i guess im busted LOL!!!! there goes my 15 min. of fame
sirtef9
May 17, 2025 04:53 PM
ekhaze
Mar 25, 2011 01:57 PM
JDMB20TDA
Oct 24, 2007 12:22 AM
vtec_lude
Mar 16, 2007 02:52 PM
Just Another Civic
Aug 15, 2005 04:42 AM
