Countershaft bearing snap ring.
Old Oct 22, 2007 | 07:11 PM
JDMB20TDA's Avatar
Default Countershaft bearing snap ring.
got trans apart replaced mainshaft bearings and now I cant get the countershaft to fall into place.
the only thing I can think of that could be causing this is a metal ring on the mainshaft that has a L shaped tab on it under the upper main bearing.
I have tried 3 times and still cant get the snapring to fall into place.
if there are any tips to getting this right let me know, thankyou.
Old Oct 22, 2007 | 10:29 PM
JDMB20TDA's Avatar
Default Re: Countershaft bearing snap ring. (JDMB20TDA)
Just needed to give the tranny a good shake. all is well
Old Oct 23, 2007 | 05:08 AM
B16B_coupe's Avatar
HRD PKR
i was goin to say all ya gotta do is turn it up side down and shake it around and it will be set, glad you found out
Old Oct 24, 2007 | 12:22 AM
JDMB20TDA's Avatar
Default Re: Countershaft bearing snap ring. (B16B_coupe)
thanks car drives like new. errr kinda
sirtef9
Transmission & Drivetrain
May 17, 2025 04:53 PM
XpL0d3r
Jul 27, 2008 09:35 PM
LsTurbo91
Jul 16, 2002 08:00 PM
