Axle leaking from driver side
Old Apr 15, 2009 | 07:57 PM
OOOtony's Avatar
Default Axle leaking from driver side
i did a swap about a month ago but havent drove it around much i notice there is a lil oil on the ground.
and when i lift up the car i can see oil dripping from driver side axle.
its not pouring out its just drips after i start the car.
can it be its not in all the way?
wanna see what it could be before i take it out and put it back in and might have the same problem.
Old Apr 15, 2009 | 08:58 PM
bcpEG's Avatar
Default Re: Axle leaking from driver side
Check your cam seals
Old Apr 16, 2009 | 01:24 PM
OOOtony's Avatar
your right i think it might be the axle seal
Old Apr 16, 2009 | 03:22 PM
champLSinteg's Avatar
Axles dont have oil. They are filled with grease. Is the oil coming from near the hub/wheel or the tranny side?
Old Apr 16, 2009 | 06:12 PM
HONDRETTI's Avatar
i'd say its your oil sending unit
Old Apr 16, 2009 | 06:38 PM
twentyhurtz's Avatar
hmm, you need to park it and get a better idea of where exactly its dripping, it it the axle seal at the transmission? coming off the back of the block?
Old Apr 16, 2009 | 07:38 PM
j_bizach's Avatar
possiblly tranny leaking from around the axle. Sounds like u got a bad seal in the trans
Old Apr 18, 2009 | 07:39 AM
OOOtony's Avatar
ill take a look again and get some pics up before i go on trying to fixing something im not sure
Old Apr 18, 2009 | 07:40 AM
OOOtony's Avatar
could it possibly be because my crossmember is off? its a 90 integra
Old Apr 20, 2009 | 12:11 PM
Vampire2o9's Avatar
thats was what I was thinking. The seal or ring that is on the inner side of the tranny where the axel goes.
Old Apr 22, 2009 | 10:50 PM
megaman_x's Avatar
its leaking from the battery..
mattbatson
Apr 24, 2010 03:56 AM
8083tcman
Dec 30, 2008 08:43 PM
Hyjnx
11
Feb 13, 2007 04:14 AM
kihun_cha
Jan 20, 2006 10:36 PM
Jer'rome
Sep 30, 2004 06:14 PM
