8 LB flywheel good for Boost???
when i was NA i got a 8lb flywheel with my clutch set up... now im turbo should i keep the 8lb flywheel? please give the goods n bad info.. thanx...
i haven't ever driven with one but some things i know..
the engine will rev quicker, however there is less inertia to get you off the line (less rotating mass) so you may have to rev a little higher to get a movin'.
mike
mike
Ill be keeping an eye on this post aswell.
My setup will be running tomorrow night. I've got a 7lb fidanza flywheel. I hope its going to be fine.
i have the jun ultralight chromoly flywheel...
i think its great...
the advantages on a NA car apply to a FI car... the disadvantages apply also..
but mostly its just less inertia for starting off...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patdemps »</TD></TR><TR><TD CLASS="quote">Ill be keeping an eye on this post aswell.
My setup will be running tomorrow night. I've got a 7lb fidanza flywheel. I hope its going to be fine. </TD></TR></TABLE>
PLEASE LET ME KNOW HOW DOES IT FEEL. AT LAUNCH N GOIN IN/OUT OF BOOST..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeMAN »</TD></TR><TR><TD CLASS="quote">i haven't ever driven with one but some things i know..
mike</TD></TR></TABLE>
so is less rotating mass good or no??? lets say i rev at lik 4k n launch thats No good? should i rev more?
im sportin the fidanza 7.5 1st gear is definately nothin until about 5 or 6k but its takin teh tires off then anyway...
its extremely fun, I don't know why people make such a big deal about inertia, but if you like to downshift, keep the 7pounder, its a lot of fun, and should help revving the little bugger out
i have a 7lbs fidanza and it does make a difference alot of difference so much that my dad drove my car and even he felt it saying what u done the revs shoot up
lolz
but im only n/a at moment ready to go turbo so dnt know what it will b like with boost
lolzbut im only n/a at moment ready to go turbo so dnt know what it will b like with boost
the lighter the flywheel, the quicker the revs will rise AND drop.
For ROAD RACING applications, the 6-8lbs flywheels are recommended.
For DRAG RACING applications, the 10-12lbs flywheels are recommended.
Go as light as possible. More flywheel weight for turbo cars is an internet myth, kind of like LS trannies are best for boost, both are total BS.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared »</TD></TR><TR><TD CLASS="quote">Go as light as possible. More flywheel weight for turbo cars is an internet myth, kind of like LS trannies are best for boost, both are total BS.</TD></TR></TABLE>
i agree with Jared... and it's all in your launch for drag racing. with street tires your rpm will drop 1.5-1k rpm...with slicks 1.5K+ rpm. this is when you learn how to slowly slip your clutch instead of dropping it...or just launch at close to redline.
i had the comptech 8.5lb flywheel in my old setup (LS turbo/gsr quaiffed tranny) and man that thing kicked ***! the flywheel helped out a great deal with the lag that was incorporated with my non-ballbearing snail.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unjockable »</TD></TR><TR><TD CLASS="quote">so should i stick with my fidanza? to me the revs don't drop as much as everyone says and it's not hard driving it on the streets. </TD></TR></TABLE>
yes just stick with your fidanza...since you're already used to it anyway. revs dropping is overated IMO. i know i haven't tried anything lower than 8lbs but at 8lbs, how fast/far the revs drop can still be controlled by shifting a little faster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsVtec... »</TD></TR><TR><TD CLASS="quote">On the XACT site it says " a lighter flywheel may reduce turbo lag"</TD></TR></TABLE>
but how light? 12lb light or 8lb light?
i have a 7.5 lb fidanza flywheel, the motor revs realy fast and spool up is sick but to get you off the line it kinda sucks cus you will loose some low end grunt, and it is hard some times to keep the turbo spooled between shifts also, i guess if i had to do it again i wouldnt get one that light probly like a 12lb or something
I just install my new clutch setup ACT HDPP w/ no spring 6 puck and 7lb Fidanza, its alright, but anyway my turbo should be in this weekend so lets see hwo it goes.
