Transmission & Drivetrain Gearboxes, Differentials, Clutches
Is honda MTF still good/safe
Old 05-21-2013, 12:15 AM
peteyparado's Avatar
Default Is honda MTF still good/safe
Got my new used tranny in. S80 ITR helical LSD trans.
been using honda mtf with my GSR trans, can i still use the honda mtf?
its a daily driver an 1/4 mile car once a month..
thanks
Old 05-21-2013, 06:26 AM
Gearspeed-Performance's Avatar
Default Re: Is honda MTF still good/safe
thanks
Yes Honda MTF is good as long as you change it regularly. Torco MTF/RTF is good as well.
Old 05-21-2013, 06:49 AM
MR.johnson's Avatar
not a fan on honda fluid.
Old 05-22-2013, 08:35 PM
sicc22's Avatar
Are you serious right now!!!
Anyways I can vouch for HONDA MTF. If I use anything else my tranny grinds bad. Yes I know I need to replace the syncros.... Blah blah blah. There are two companies that ppl believe in Honda and GM tranny fluid. All the other stuff is great, but not if you are trying to extend the life of a beaten piece of equipment. I would love to run redline in my trans but I can't, I've tried.
Old 05-22-2013, 08:39 PM
GagnarTheUnruly's Avatar
Lots of people swore by GM Synchromesh with friction modifiers. That has become hard to find lately but it appears to be the same stuff as AC Delco Synchromesh with friction modifiers: Part # 10-4014
Old 05-22-2013, 08:50 PM
I serve phở for my babies
ohsnapzafingcu's Avatar
honda mtf has never failed me, i've used it in a lot of applications.. i really can't tell the differences between all of the fluids. I'm using honda mtf on my 550 whp k trans right now and it's doing very well
Old 05-23-2013, 03:35 PM
thanks for the input honda MTF it is..
Old 05-23-2013, 03:49 PM
Runnerdown's Avatar
Well I'm not trying to be a dick, but that is literally the WORST fluid for that application. It may be shifting ok but the gears will wear like crazy. I only use it on stock cars.
Old 05-23-2013, 04:59 PM
what would you recommend? why would torco's MTF or RTF be better?
Old 05-23-2013, 08:38 PM
what would u use then?
Old 05-24-2013, 03:02 AM
Runnerdown's Avatar
For DD, stock to bolt ons the honda or other synchromeshs work great. But for any type of racing or higher power setups the honda mtf does not cut it. I love oem honda but the mtf breaks down seriously fast with heat and does not offer enough wear protection.
I built k transmissions for scca world challenge touring cars and found out early in testing that these fluids were not adequate. In my experience the motul gear 300 and motyls worked really well. For high power setups and road racing the redline lightweight shockproof was amazing for keeping gear wear down. But the redline has some funky properties to it and I would make sure the transmissions I put it in were inspected and refreshed on a regular basis as a far as synchros go.
Old 05-28-2013, 10:30 PM
blaza's Avatar
so how many miles before you would flush your trans in a stock trannyy with honda mtf?
krazycivic4u
06-03-2006 08:18 PM
zx2gotboost
11
02-19-2006 09:20 PM
Tex Blackwell
08-14-2004 11:10 PM
keys
12-12-2002 10:50 AM
NighthawkR184
12-07-2001 04:28 PM
Quick Reply: Is honda MTF still good/safe
