EG aouto to manual HELP.
Are there wires that are under the center console that were part of the auto trans that need to be removed..car has nor power to the starter now i start it by jumping the starter.help.....
Re: EG aouto to manual HELP.
At the plug under the center console, jump the 2 large wires together.
^ yes do that. you need to wire the 'park' position so you can start it. you can use 'neutral' wires also. and while your in there, wire the reverse lights. it's the two wires in the bottom middle under the two fat top middle park wires...the reverse light wires are small yellow and green i think...run these to the reverse sensor.
