Tranny problem, Cant figure what it is
hey i feel like a noob asking this question, but
at the moment i have a b16 tranny with a stage 2 clutch, stock flywheel.
today on the freeway, while in gear, if i let the gas go, i easily poped the gear back into neutral without stepping on the clutch, and it went in like butter.
did it for 5th and 4th gear.
is it a 5th and 4th gear pop out?
thanx!
thanx!
Re: Tranny problem, Cant figure what it is
well some signs of that is normal. you can shift any manual trans w/ out a clutch at the correct rpm, so it should apply. Since you mentioned it goes in and out like butter that might be a problem, synchro or fork.
yea theres no noise what-so-ever as i can put it back into neutral without clutching it.
First i obviously thought it was a pop-out, but shouldnt a pop-out even sound bad?
you should be able to pull the car out of any gear without touching the clutch. Its probably your clutch or linkage that makes it feel so smooth. My stage 4 and urethane bushings feel the same way. just slides out of gear but not on its own. Everything runs right correct? your problem is that is slides out of gear too easily? no grinding or missing gears?
chris408
04-22-2004 03:51 PM
RTW DC2R
09-05-2003 07:36 AM
