Zero Compression Results
Old Dec 7, 2006 | 07:41 PM
jk11blueboi's Avatar
Default Zero Compression Results
Got a motor from a guy and he said it came out of a running car. Its a 2000 b16 and when i went to start it up, it sounds like theres no compression like the spark plugs were removed. the motor turns over but doesnt have any compression. Did a compression test and all cylinders came up 0. I checked for spark and fuel and theres spark and fuel. could it be bent valves? could it be a blown head gasket? i took off the head today and the bottom end seems fine but is there a way to tell if the valves are ment without taken them out of the head. by looking at them, the valves are seated normally
Old Dec 7, 2006 | 10:05 PM
Scott_Tucker's Avatar
Default Re: Zero Compression Results (jk11blueboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jk11blueboi &raquo;</TD></TR><TR><TD CLASS="quote">Got a motor from a guy and he said it came out of a running car. Its a 2000 b16 and when i went to start it up, it sounds like theres no compression like the spark plugs were removed. the motor turns over but doesnt have any compression. Did a compression test and all cylinders came up 0. I checked for spark and fuel and theres spark and fuel. could it be bent valves? could it be a blown head gasket? i took off the head today and the bottom end seems fine but is there a way to tell if the valves are ment without taken them out of the head. by looking at them, the valves are seated normally</TD></TR></TABLE>
Just pour some solvent in the combustion chambers with the head upside down and see if the solvent leaks past the valve seats.
HondaMike2112
26
Jul 7, 2019 01:16 PM
osgn
Mar 1, 2009 01:31 AM
Under Con. CrX
Feb 20, 2008 10:20 PM
guymosiris
Mar 31, 2007 12:45 PM
fakeownzjoo
Sep 21, 2006 04:31 PM
