Tranny Grind questions
Old 05-27-2004, 05:22 PM
endlessdv's Avatar
Default Tranny Grind questions
I recently traded a car with my friend. It has the JDM y1 LSD tranny. Heres the deal. Its hard to get into 2nd gear, sometimes I would have to shove it in. And in Third Gear it grinds when I shift from 2nd-3rd. Anyway to fix this problem? Im pretty sure the teeth are all messed up. Should I just buy a new one? Is there anyway I could buy a new LS tranny and swap over the LSD?..
Thanks
EDIT. Its a y1 LSD transmission
Modified by siamturbo at 2:42 AM 5/28/2004
Old 05-27-2004, 05:23 PM
Ricey McRicerton's Avatar
Default Re: Tranny Grind questions (siamturbo)
If you're brave enough you can open up the tranny you have and replace the gears/synchros.
Also, you may want to try some of the Penzoil Synchromesh FM. It may help your problems.
Old 05-27-2004, 06:28 PM
FERIOkid's Avatar
Default Re: Tranny Grind questions (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">If you're brave enough you can open up the tranny you have and replace the gears/synchros.
Also, you may want to try some of the Penzoil Synchromesh FM. It may help your problems. </TD></TR></TABLE>
what he said...
Old 05-27-2004, 07:29 PM
Sketch_hs's Avatar
Default Re: Tranny Grind questions (slowdx9585)
^you want the friction modified.
10x better IMO
Old 05-27-2004, 08:45 PM
imitati0n's Avatar
Default Re: Tranny Grind questions (Sketch_hs)
i was havin tranny probs on my d15 and i put in some GM Synchromesh Friction Modified... it helps it get into gear smoother, but it still grinds :\
Old 05-27-2004, 11:30 PM
endlessdv's Avatar
Default Re: Tranny Grind questions (imitati0n)
Does that GM Syncromesh really help alot?... They go for 15 bucks. I dont wanna buy it if it wont help at all.
Old 05-28-2004, 11:09 PM
imitati0n's Avatar
it helped mine out a little.... my synchro are pretty messed (cause my sister drove my car while i was away at school and i hadn't replaced the trans oil since i thought it was just gonna be sittin in my driveway)
but about the GM... it helps if u get the GM synchromesh Friction MOdified stuff.
My car slips into gear a lot easier now, and it doens't grind as bad... I can almost drop 2nd as fast as i used to be able to without getting mad-style grinds. Goto ur GM dealer, I got 2 quarts for $21... it's worth it to give it a shot. Plus if it doesn't work just drain it right out and save it for your new trans
Old 05-29-2004, 05:58 PM
Sketch_hs's Avatar
it really helped me out. but ya gotta wait like 500 miles for it to really works. it's got to like bond with the metals or something. The friction modifiers also wear out quick in honda trannys. you'll need to change the fluid every 8000 miles or so to keep it feeling great. My tranny seems to get better with every fluid change (more pure GM Friction Modified Gold!)
yes its expensive. but worth every penny IMHO.
ashb82
Transmission & Drivetrain
10-06-2010 03:30 PM
LUDEacris
04-21-2005 12:18 PM
kaoss_11
23
09-13-2004 09:57 AM
biggdogg
01-15-2004 03:16 PM
Spoon Si
09-11-2002 12:11 PM
Quick Reply: Tranny Grind questions
