Wonky Idle
Old Jul 5, 2001 | 10:12 PM
Phuc yiu's Avatar
New User
Default Wonky Idle
Whenever I turn on my car, I let it warm up a bit then drive it. But for the first 10mins or so when I drive it, whenever I stop though, the idle drops to like 200rpm. After that whenever I stop it idles at ~500rpm. Whats the deal?? I replaced the cap, rotor and wires and it still does this!! Any ideas?
Old Jul 7, 2001 | 10:53 PM
Phuc yiu's Avatar
New User
Default Re: Wonky Idle (Phuc yiu)
come on...some one must have an idea
Old Jul 7, 2001 | 10:56 PM
raene's Avatar
If it does this ALL the time then it's something related to the idle system. Like the fast idle valve. Or maybe your idle speed just needs to adjusted upwards.
Old Jul 8, 2001 | 11:07 PM
Phuc yiu's Avatar
New User
Default Re: Wonky Idle (raeneshadow)
What does the fast idle valve look like? and where is it located?
Old Jul 8, 2001 | 11:58 PM
Comptech98GSR's Avatar
my 98 GSR does the same damn thing
Old Jul 9, 2001 | 12:28 AM
raene's Avatar
Where's it located?
I believe that's car-specific. It's usually on the firewall. It'll have an inlet vacuum tube and an outlet vacuum tube.
[Modified by raeneshadow, 1:28 AM 7/9/2001]
Old Jul 9, 2001 | 08:26 AM
maxim's Avatar
mine does the same thing when it gets warmed up, but mine started after I put underdrive pulleys on. I even tried tightened the idle controller and it worked for about a week and then was back to the low rpm thing again.
Old Jul 9, 2001 | 01:04 PM
Phuc yiu's Avatar
New User
my car is a 96 civic ex, so would it still be on the fire wall?
Old Jul 10, 2001 | 10:09 AM
Phuc yiu's Avatar
New User
would the fast idle valve need adjusting or replacing?
Old Jul 10, 2001 | 01:21 PM
raene's Avatar
I'd help you out if I knew. Best thing is probably to pick up a cheap manual like Haynes... it'll at least show a pic and give some general instructions on how to adjust it. Even better would be to pick up a Helms manual, but they're expensive. Sorry I'm not more help.
spock_rocker
Oct 17, 2007 08:11 AM
Cuong-nutz
Nov 25, 2004 10:34 AM
killa_lude
Aug 16, 2003 08:33 AM
