rack and pinion ?
Old May 24, 2003 | 07:02 PM
beeboyee's Avatar
Default rack and pinion ?
just replaced it ...
but i get no power steering?
what happend during the process?
all lines are attached and power fluid is all tip top
anything else i was suppost to do?
TIA
Old May 24, 2003 | 07:43 PM
TREVER's Avatar
Default Re: rack and pinion ? (beeboyee)
It's pretty straight foward why did you replace it?
Old May 24, 2003 | 08:01 PM
beeboyee's Avatar
Default Re: rack and pinion ? (TREVER)
cause both boots were torn and slinging grease all over the place
Old May 24, 2003 | 08:21 PM
TREVER's Avatar
You had power assist before you changed it. Did you turn it from lock to lock several times to bleed the air?
Old May 24, 2003 | 08:41 PM
beeboyee's Avatar
lock to lock? is that how you bleed them?
Old May 24, 2003 | 08:52 PM
TREVER's Avatar
yep
Old May 25, 2003 | 01:45 AM
beeboyee's Avatar
tryed it wont work ;D is there another way?
Old May 25, 2003 | 01:37 PM
PinchE NegRo's Avatar
up
Old May 25, 2003 | 11:58 PM
beeboyee's Avatar
Default Re: rack and pinion ? (EK-TUNED)
help! wheres the bleeder?!
Old May 27, 2003 | 10:45 AM
beeboyee's Avatar
still no power steering!
wheres the honda guru when you need em'?
Old Jun 3, 2003 | 01:09 PM
beeboyee's Avatar
Old Jun 12, 2003 | 12:02 PM
beeboyee's Avatar
out with the power steering
thanks guys!
Old Jul 8, 2003 | 08:06 PM
garagespecial
Guest
Posts: n/a
your welcome
AccordEX1991
May 29, 2006 02:50 PM
sohc_freak
18
May 24, 2006 07:56 PM
1994IntegraRS
Aug 18, 2004 05:19 PM
