Battery exploding
Old Jul 1, 2005 | 08:45 AM
White V6's Avatar
Default Battery exploding
Well this morning i was a awoke to to the song of my grandparents saying, i think something explode in the engine. so i when to take a look and the top of it was craked a hole in both sides. The battery was still smoking. Dose any one know what made this happen ???????????????????????
Old Jul 1, 2005 | 09:08 AM
deserthonda's Avatar
Default Re: Battery exploding (White V6)
do you have any non factory stuff installed under the hood?? wiring near the battery??
Old Jul 1, 2005 | 09:13 AM
P_Adams's Avatar
A spark ignited a hydrogen explosion inside the battery. You didn't mention if it was while starting (more common than) or just sitting there.
1) Just starting: arc caused by poor cable connection at battery
2) Just sitting there: Internal short (very uncommon)
3) Running: Alternator overcharged battery causing it to overheat, etc.
P
Old Jul 1, 2005 | 09:45 AM
White V6's Avatar
Default Re: Battery exploding (deserthonda)
its all stock
Old Jul 1, 2005 | 11:28 AM
raceACCORDingly's Avatar
this happend to my friend's mom's van. she was parked, listening to the radio, changed the song and kabooom! my friend just cleaned up all the acid and put another one in..
Old Jul 1, 2005 | 11:32 AM
although very rare it could have been an intenal short if no wiring or anything else is close to battery ,,, after replacing make sure you have the charging system checked out voltyage regulator could be faulty thus it overcharged battery
Old Jul 1, 2005 | 12:43 PM
goingtobefast's Avatar
Low on water or discharge tube was clogged?
Old Jul 1, 2005 | 03:16 PM
Accord_boy619's Avatar
If the battery was low on acid/water it could explode. It happens once in whlie to our generators at work.
Old Jul 1, 2005 | 09:11 PM
White V6's Avatar
Default Re: (Accord_boy619)
A lot of acid came out and water to when i opened the hood the battery was smoking
Modified by White V6 at 6:38 PM 7/29/2005
AccordJDM413
Jun 25, 2019 07:11 PM
gsrpedro
14
Feb 5, 2008 01:14 PM
Project X
Feb 24, 2004 05:44 AM
