wiring help
Old Jul 24, 2004 | 12:57 PM
Hybrid2Be's Avatar
Default wiring help
ok. i have a 93 Civic. I just put a 2000 integra engine in it. can someone give me some details on the wiring using the 2000 integra ecu. everyone talks about using the obd1 ecu., but i already have the obd2. more details the better. thank you
Old Jul 24, 2004 | 01:30 PM
sit220's Avatar
Default Re: wiring help (Hybrid2Be)
u need to be more specific
what engine u got ?
ls
gsr
type r
Old Jul 24, 2004 | 01:54 PM
PHiZ's Avatar
Default Re: wiring help (sit220)
OBD1 to OBD2 conversion harness ~150 dollars, plus the labor of wiring it up.
OBD1 ecu, 100-200 dollars. Plug and play...
-PHiZ
Old Jul 24, 2004 | 02:20 PM
Fobtions's Avatar
Default Re: wiring help (PHiZ)
not too mention if the 2000 gsr ecu is a usdm motor. you gotta feed it every wire it needs so you wont throw any CEL's. i:e crank fluctuation sensor, gas tank sensor thing, secondary o2.
do what everyone else does and rechip your original ecu, if its a p28.
dwarfsinhondas
Engine Management and Tuning
Apr 14, 2008 04:50 PM
Hybrid2Be
Feb 6, 2004 02:20 PM
hybridb18
Feb 1, 2003 09:30 PM
