Winshield wSquirter problem!!! Help!!!
Old Feb 12, 2002 | 12:25 PM
scrubachu's Avatar
Default Winshield wSquirter problem!!! Help!!!
my windshilked squirteers stopped working out of nowwhere. i have not a clue why. i checked the fuse for the wipers, its ok, everything works except the squirters. any ideas??
Old Feb 12, 2002 | 01:37 PM
REDBARON's Avatar
Default Re: Winshield wSquirter problem!!! Help!!! (scrubachu)
Check your lines, and also if there's fluid in the reservoir. Do you hear a noise when you attempt to get fluid to squirt out?
Old Feb 12, 2002 | 01:42 PM
Crazydave's Avatar
Default Re: Winshield wSquirter problem!!! Help!!! (VTECHatch)
maybe you need to get those LED squirters
really though....check the actual ports themselves.. and makes sure they are not pluged.. and check your fluid level...
put some distilled water in it and run the squiter motor.. make sure the motor is working
[Modified by Crazydave, 2:42 PM 2/12/2002]
Old Feb 12, 2002 | 02:08 PM
ThePunk's Avatar
Default Re: Winshield wSquirter problem!!! Help!!! (Crazydave)
The squirter jets themselves can clog over time.
If so, pull them off and soak in hot water/simple green solution for a while...
Old Feb 12, 2002 | 05:38 PM
87posCRX's Avatar
Default Re: Winshield wSquirter problem!!! Help!!! (Jonesy69)
mine have never worked, and there isnt a sound when i hit the switch
Old Feb 12, 2002 | 08:00 PM
FitCRX's Avatar
Default Re: Winshield wSquirter problem!!! Help!!! (87posCRX)
Dude I think all you need to do it upgrade!!!!
Old Feb 13, 2002 | 05:28 AM
REDBARON's Avatar
Default Re: Winshield wSquirter problem!!! Help!!! (FitCRX)
If you don't hear any noise coming from the motor that runs the squirters, then you more than likely need to replace it.
Old Feb 13, 2002 | 05:35 AM
speedymon's Avatar
Yeah to LED nozzles
Old Feb 13, 2002 | 05:50 AM
Spade's Avatar
Default Re: Winshield wSquirter problem!!! Help!!! (ThePunk)
There is a quick and easy way to tell if they are clogged. Take a sewing neetle and poke it into the outlet. If they work after that then take them off and soak them, no point in soaking them if there not clogged.
Old Feb 13, 2002 | 06:03 AM
Greyout's Avatar
Default Re: Winshield wSquirter problem!!! Help!!! (Spade)
the 5-10 lbs of the motor, lines, and filled water tank now sit comfortably in my attic
Old Feb 13, 2002 | 06:07 AM
MrBite's Avatar
*points* HAAA HAAA the censor's off
Old Feb 13, 2002 | 10:42 AM
Tweakmeister's Avatar
Default Re: Winshield wSquirter problem!!! Help!!! (MrBite)
Don't worry, mine quite on me too.
I know the lines look terrible so I think I'll replace them while I'm at it. I just have to crack open the Helms to figure out how to reach the motor(s).
Old Feb 13, 2002 | 10:50 AM
Greyout's Avatar
Default Re: Winshield wSquirter problem!!! Help!!! (Tweakmeister)
its basically where your resonator would be, if your resonator was on the driver side.
Old Feb 13, 2002 | 01:00 PM
iceburgslim's Avatar
Default Re: Winshield wSquirter problem!!! Help!!! (JDM LUDE)
Get a thin metal wire (not an electircal wire with a rubber sleeve) and stick that in the hole on the washer nozzle jets, this should do the trick to unclog them (that's what we do at work). Later!
D.WERKZ
Apr 5, 2008 05:40 PM
sTill JDM
Jan 10, 2007 05:16 AM
yesterdayz
Oct 9, 2003 06:19 PM
rsx03
Oct 12, 2002 10:41 AM
scrubachu
Feb 12, 2002 08:24 PM
