will there be problems if my speedometer cable is out??
Old Jun 28, 2002 | 09:17 PM
dingusjt's Avatar
Default will there be problems if my speedometer cable is out??
i just swapped new engine into my car and am anxious to start it up and drive it to see how badly i screwed things up, anyway my speedometer sensor thingy that drops into the tranny got messed up so i need to get a new one, meanwhile i want to know if by not having it in there something could get messed up, besides my speedometer not working....let me know asap cause i am waking up bright and early to get this thing running.
Old Jun 29, 2002 | 03:20 AM
ULTRA911's Avatar
Default Re: will there be problems if my speedometer cable is out?? (dingusjt)
yes, you can drive! who say you couldn't? but yea, i driven without a speedo cable or a gauge cluster & it runs fine. your speedo won't work & your odometer won't work either. check engine will come on after couple of miles.
[Modified by ULTRA911, 12:20 PM 6/29/2002]
Old Jun 29, 2002 | 09:22 AM
willydawsonv's Avatar
Default Re: will there be problems if my speedometer cable is out?? (ULTRA911)
just make sure that no oil leaks out
Old Jun 29, 2002 | 12:14 PM
Lsos's Avatar
I don't think VTEC works without a speedo.
Old Jun 29, 2002 | 12:23 PM
dingusjt's Avatar
Default Re: will there be problems if my speedometer cable is out?? (Lsos)
anyone else know anything about this, cause thats what i swapped in, SOHC VTEC.
Old Jun 29, 2002 | 07:57 PM
ULTRA911's Avatar
Default Re: will there be problems if my speedometer cable is out?? (willydawsonv)
oil from where? the sensor?
you know what's weird, i could still hit vtec the time i had a broken speed cable, but i can't hit vtec when i had a broken speed sensor.
Old Jun 29, 2002 | 11:41 PM
M-EJ1's Avatar
Yes, because VTEC requires that the speed sensor be functional, not necessarily the speedo cable or the gauge.
Old Jun 30, 2002 | 09:34 AM
hybridcrx's Avatar
Default Re: will there be problems if my speedometer cable is out?? (matt-eg)
yeah, if the speedo cable is not in, you will have no vtec. In my b16 when I replaced my tranny I didn't push the speedo cable all the way in and the thing drove like a dog, and wouldn't rev past 6500 or so, then a few minutes I threw a cel. I went back to my house, checked the code, and sure enough it was the vehicle speed sensor. Pushed in the speedo cable a little more, and voila - vtec.
in10ceCiviC
Mar 4, 2007 12:53 PM
GsrTurboCRX88
Sep 21, 2006 06:43 PM
aka
13
Dec 5, 2005 05:30 PM
ImportPower13
Aug 26, 2005 07:12 AM
fastcat1
Dec 31, 2002 01:13 PM
