Wideband map sensor chart, excel spreadsheet enclose, Check it out
I have made a honda obd1 map sensor voltage to actual map reading crossreference chart.. Can someone check it out to make sure my numbers are correct.. Boost is shown in PSI and vacuum is shown in PSI and HG.. Let me know if these are correct..
http://www.remuplk.com/mapobd1chart.xls
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kpt4321 »</TD></TR><TR><TD CLASS="quote">Where did you get the information from for this?
Looks good.</TD></TR></TABLE>
http://www.pgmfi.org From the WiKi section.. Its also on hondata's website.. I just used 2 points on a graph and did the calculations..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fox297 »</TD></TR><TR><TD CLASS="quote">Looks nice, is the graph linear? Also, is this the same for OBD0?</TD></TR></TABLE>
It might me different for obd0 im not sure.. What I did on my crx is put a B16 throttlebody on it and ported out the intake manifold a little bit to make it match.. And then just used the obd1 map sensor on top of the throttlebody..
hatchinprogress
Nov 23, 2004 08:21 PM
