why does my car always shock me?
open up your nitrous bottle a little and let it bleed just before getting out...
actually I'm willing to bet that your hind sliding across the seat is causing a build-up on your body. Try changing the way you get out of your car.
did you know that everytime you get shocked, you are actually putting little holes in your skin?!? I wrote a piece on this a LONG time ago, for a website I used to run. Here's an archive of the text.
http://hogens.com/review/info/esd/esd.htm
my car shocks me now too.. i think it just has to do with the time of the year. its not a humidity thing because i just drove it from texas to california and it still zaps me every time i touch the top of the door on the way out
Dammit, you people are making my engineering classes come out....
Ok, here's what happens. The tires moving across the ground causes a static buildup in the car. It works just like when you drag your feet over carpet. Do it long enough and you build up static in yourself even if you are wearing rubber shoes. Touch metal and pow. The car works the same way when it drags its tires over the ground. Grippy tires make this worse, as they grip the ground harder and build up more static.
When you touch the ground, then the car, all the electricity instantly arcs through you into the ground. If you touch the car first, electricity moves into you so that you and the car have the same charge. Static then passes out into the ground when you touch it. The car doesn't shock you, because you and the car already have the same charge.
P.S. Cold weather causes more static to build up. In the winter the car zaps you, in the summer it usually doesn't.
Yeah it is the cloth seats. Because when I had my leather, I never got shocked. For about 6 months I always got shocked. Now, I have my leathers back in and no more shock....
ok, how the hell can i get my car to shock me !!!!!!!
No no no...Your got it all wrong..You gotta get foil and wrap it around your head in a cone shape manner for one full day..and by the time you wake up itll be all gone...
G2_Fella
15
Apr 14, 2009 02:07 PM
97akwerd
Aug 5, 2005 02:42 AM
