why does it feel like i'm driving on a square tire
Old Nov 28, 2017 | 03:26 AM
Accordgurl86's Avatar
Default why does it feel like i'm driving on a square tire
When accelerating there is a lot of vibration in the steering wheel. It pulls to the Right almost at a second hand tick and feels like I'm driving on a square tire. Help me please
I don't want to pay someone else to do the work.
Old Nov 28, 2017 | 05:51 AM
DumpdEJ6's Avatar
I like the tuna here
Default Re: why does it feel like i'm driving on a square tire
Does the "tick" speed up as you speed up? Have you checked the tire for damage? Make sure you've checked the WHOLE tire, 360 degrees, because I swear the bad part is always the part that happens to be sitting on the ground.
Old Nov 30, 2017 | 08:11 PM
motoxxxman's Avatar
could be a bad axle too. often times you'll only feel a shot axle when it's under some form of load. severely lowered cars frequently smoke axles.
Old Dec 1, 2017 | 09:43 AM
accorse07's Avatar
Description of the issue points towards a bubble/bulge on one of your tires. Could be hard to spot unless on a lift or jacked up off the ground.
Old Dec 1, 2017 | 10:25 PM
turbomaniac's Avatar
could be all what others said, but if there is no vibration at deceleration it could be bent axle shaft. Start from basics (wheel balancing, checking suspention/steering joints, aligment) cause the basics are always useful and then examine the bent axle possibility.
CWBETB
12
Apr 6, 2008 03:25 PM
Mendes
Feb 21, 2008 01:46 PM
iheartintegras
Nov 2, 2007 05:47 PM
Jizzmaster Zero
12
Jun 16, 2006 02:42 PM
CRX Lee
15
Dec 27, 2003 10:15 AM
