J swap no reverse...need input
Old Nov 22, 2017 | 08:38 AM
J32a2eg666's Avatar
Default J swap no reverse...need input
My j32a2 turbo couldn’t handle the lmao 43 lbs of boost the map read maybe more.... well anyway I put a jdm j32a in and now I can’t get into reverse with the car not running and running rocking it and even putting it in reverse by our hands it will not go.... my question is can the solenoid be stuck in lock out mode preventing it from going into reverse with the car on and off and by hand? Can check the damage out in my albums......no replacement for displacement.....
Old Dec 3, 2017 | 05:06 AM
fracas's Avatar
Default Re: J swap no reverse...need input
Have you checked the lock out solenoid? I'm assuming if it was working before and now its not , that should be you issue. Im starting my j32a2 ek build now. By chance do you know anyone building motor harnesses?
JDM97EK
Oct 31, 2007 07:04 PM
ekdreamz
Dec 16, 2006 10:14 AM
vtec181
13
May 29, 2004 09:24 PM
