problem with brakes!!!bled them and still no pressure!!
Old Aug 14, 2003 | 11:49 PM
crx1856's Avatar
Default problem with brakes!!!bled them and still no pressure!!
i bled the crap out of my brakes and it seems like an endless amount of air in there. the only way i get some pressure is if i pump the brake pedal. everything is tight and i don't have any brake fluid leaking anywhere.air and brake fluid is coming out and i keep filling the master cylinder when i bleed them but still not enough pressure.(89 crx)
Old Aug 15, 2003 | 12:01 AM
K20EG's Avatar
Default Re: problem with brakes!!!bled them and still no pressure!! (crx1856)
do them one at a time
the best way ive found is using that one man brake bleeder thingy ..costs 10 bucks at any autoparts store
i usually pump the brakes 5-7 times hold down on the last pump and have someone open the valve
Old Aug 15, 2003 | 06:07 AM
BeerMan's Avatar
What exactly do you mean by no pressure? Is your mc bad?
Otherwise: bleed, bleed, bleed. I hate bleeding my brakes because I go through alot of fluid before I get them right.
Old Aug 17, 2003 | 04:12 PM
K20EG's Avatar
Default Re: problem with brakes!!!bled them and still no pressure!! (BeerMan)
did you fix it ?
Old Aug 17, 2003 | 04:17 PM
crx1856's Avatar
Default Re: problem with brakes!!!bled them and still no pressure!! (K20EG6)
i couldn't figure out what was wrong so i took it to midas. aparently, i put the calipers in the reverse order. they switched it and bled the system. now i have good pressure, but when i push the brake pedal and hold it, it will slowly move down. it will re pressurize if i release the pedal and press it again. anyone know what that means?
Old Aug 17, 2003 | 04:26 PM
K20EG's Avatar
that typicall means the Master Cylinder is Bypassing
as far as the calipers in reverse order ..i dunno ...thats an interesting one lol
drewbie
19
Aug 17, 2007 12:40 PM
Driven
Jul 23, 2003 06:21 AM
Driven
May 26, 2003 03:29 PM
TedR719
May 21, 2003 07:54 AM
CD8
Jun 18, 2002 09:30 AM
