White smoke at full throttle
Okay so like the title says I have white smoke time to time at full throttle. When normally driving there is no smoke. I haven't noticed any decrease in power also. I've done a dry compression test and got 180 across all cylinders (98 b18c1) also ran the car for 5 minutes with the radiator cap and no bubbles, also no seen oil leaks. Only problem is smoke at full throttle and my car has a strong exhaust smell after driving everyday (outside the cabin). Also spark plug 1 has a orangish brown tip and I replaced all 4 no longer then 6 months ago.
not necessarily..the seals inside could be so bad it lets coolant pass through to the intake.
Just remove it and look for coolant inside the air chamber. You can even open the throttle plate and look inside and see if there's coolant colors inside the intake manifold.
EtherEG93
Sep 17, 2005 08:18 PM
Driven
11
Oct 29, 2004 11:41 AM
