Where is this sensor? (on B20Z block) Knock sensor maybe?
Old Oct 28, 2002 | 10:11 AM
DevinW's Avatar
Default What is this sensor? (on B20Z block) Knock sensor maybe?
Hi,
Topic should have been "WHAT is this sensor..." sorry!
There's a sensor on the intake manifold side of my B20Z block and I'm not sure what it is. It's the only sensor I've come across that doesn't appear to 'unplug'.
It's near the center of the block (IM side) and it has 2 (maybe 3) wires going into it. It looks like the only way to remove it, is to remove the entire sensor assembly by using a wrench....since is has a hexagonal-nut shape underneath the rubber wire sheath. Does anybody know what this is? I don't have a Helms yet...
Also, where is the knock sensor on the B20Z? What does it look like? This sensor thing above is keeping me from disconnecting the engine wiring harness...since I don't really want to cut the wires to the sensor incase I need to use it again..
It's shaped like this:
-----IM----------
block
_
/ . \ <-sensor
\ _/
The dot ( . ) is where the 2 wires enter...the whole thing is covered in a rubber sheath..
Thanks for you help...
[Modified by DevinW, 3:15 PM 10/28/2002]
[Modified by DevinW, 3:16 PM 10/28/2002]
Old Oct 28, 2002 | 10:33 AM
nsxmatt's Avatar
Default Re: What is this sensor? (on B20Z block) Knock sensor maybe? (DevinW)
That is the knock sensor. Pull the rubber boot cover thing off and it's there.
Old Oct 28, 2002 | 11:15 AM
DevinW's Avatar
Default Re: What is this sensor? (nsxmatt)
OK, so how should I remove it? Cut the wires to it? I'll be using a 95 LS ecu, so I don't think it will be checking for a knock sensor.
Old Oct 28, 2002 | 11:34 AM
nsxmatt's Avatar
Default Re: What is this sensor? (DevinW)
Unless it's chipped I thought it would look for a 02, hmmm.
Is this the sensor your talking about??
Old Oct 28, 2002 | 11:44 AM
jdmitr's Avatar
If it has a rubber boot on it, it is the oil pressure switch! It only has one wire, and the boot comes off, and unplugs!! The sensor in the previous pic is the knock sensor, and is above the OPS.
Don't cut it!!
Old Oct 28, 2002 | 12:07 PM
DevinW's Avatar
Default Re: What is this sensor? (b20civicvtec)
The one I am talking about is just below and to the left of the one in the pic. It does have only one wire going to it. It must be the oil pressure switch then....but how do you unplug it, so I can fully disconnect the wiring harness?
Old Oct 28, 2002 | 12:39 PM
fire7882's Avatar
it just pulls off
Old Oct 28, 2002 | 03:08 PM
DevinW's Avatar
Default Re: What is this sensor? (fire7882)
Are ya sure? Hehe I don't want to break it or anything
Old Oct 28, 2002 | 03:29 PM
fire7882's Avatar
The one on my first gen b16a just pulled off. It was stuck on there tight but it eventually came off without damaging anything.
Old Oct 28, 2002 | 04:57 PM
avividmemory's Avatar
would the one you're talking about be the oil pressure sensor?
Old Oct 28, 2002 | 05:35 PM
tinkerbell's Avatar
Default Re: What is this sensor? (SpoolinLS)
go hard, remove the boot and you will expose the sensor...
t..
EFjoe91
Mar 5, 2016 06:17 AM
hoezee
Oct 6, 2008 10:40 AM
ExCon
Jul 19, 2006 01:56 PM
CM-R
Mar 29, 2002 12:34 AM
MrFatBooty
Dec 12, 2001 10:11 AM
