Where to get TPS Sensor Bolts....
Old Mar 21, 2005 | 04:27 AM
MugenB16A2's Avatar
Default Where to get TPS Sensor Bolts....
I just picked up an OBD-II B16A2 Throttle Body from a friend and it is missing the TPS Sensor (He bought a 70mm TB and used the stock TPS on it...)...
Anyways, I am wondering how to get the two bolts that secure the TPS to the Throttle Body itself...
I know that USDM sensors have those pesky rivet looking screws that have no heads to remove them, and the JDM have regular Philips style screws...
Can I order these at my local Honda Dealer??? If so, what part number???
Thanks in Advance...
Old Mar 21, 2005 | 06:16 AM
PrettyLude's Avatar
you can get it at the dealer or you can even get it at the hardware store, just bring the tb with you when you go
Old Mar 21, 2005 | 07:16 AM
IN VTEC's Avatar
Default Re: Where to get TPS Sensor Bolts.... (MugenB16A2)
M5x.8x16mm
I believe a 16mm length works fine as long as you use a M5 lock washer and a regular washer with the machine screw/bolt. A 20mm length will bottom out on the throttle body before it ever seats.
I usually use the pan head machine screws, but you can use whatever style of fastener head you want. Socket head cap screws are ok too.
seelyd
Feb 5, 2007 10:01 AM
haroldthefly91crx
Oct 15, 2006 11:24 AM
093SiLude
Feb 2, 2004 04:28 PM
deacs
Oct 7, 2002 10:30 AM
SIcivic10
Sep 29, 2002 05:33 PM
