When changing cams do ya re-adjust the valve lash or not?
Old Dec 30, 2006 | 10:13 PM
vtec25's Avatar
Default When changing cams do ya re-adjust the valve lash or not?
In DOHC Vtec engine.
And how does it sound/run? this is for those who dont adjust.
Old Dec 31, 2006 | 01:01 AM
ekb16's Avatar
i believe u should adjust them after replacing new cams...if u dont it might make a clickin sound when driving or idle
Old Dec 31, 2006 | 06:36 AM
vtec25's Avatar
Default Re: (ekb16)
i thought it would but i wanna know if anyone has done it without adjusting them and has gotten away with it.
Old Dec 31, 2006 | 06:50 AM
non-VTEC's Avatar
Default Re: (vtec25)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec25 &raquo;</TD></TR><TR><TD CLASS="quote">i thought it would but i wanna know if anyone has done it without adjusting them and has gotten away with it.</TD></TR></TABLE>
why? your right there and it only take another 20-30min to do the whole job correctly instead of half assed.
Old Dec 31, 2006 | 09:57 AM
EE_Chris's Avatar
Default Re: When changing cams do ya re-adjust the valve lash or not? (vtec25)
Half-assed jobs are what keep people posting questins around here...that and using 'half-assed' parts.
When changing cams, you set the valve lash. You're not re-adjusting it because it was never adjusted in the first place. The old clearances were good....for the old cams.
Old Dec 31, 2006 | 11:54 AM
Scott_Tucker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec25 &raquo;</TD></TR><TR><TD CLASS="quote">In DOHC Vtec engine.
And how does it sound/run? this is for those who dont adjust.</TD></TR></TABLE>
The base circle diameter of two different cams can be quite different therefore your lash could be significantly loose or tight when installing a new cam. Installing a cam without adjusting the valve lash isn't even an option.
Mike Lowwryyy
Jun 11, 2014 01:07 PM
J-Spot
22
Sep 27, 2007 10:15 AM
redlseg
Jun 27, 2005 06:53 AM
aut0tek
May 26, 2004 11:19 AM
sikcrx80
May 20, 2003 06:49 PM
