wheel size affecting whp
Old Jan 12, 2003 | 01:53 PM
NightHawkC5's Avatar
Default wheel size affecting whp
Lets say ur stock wheels on ur car are 14 inch and u change them to 17 inch will this affect whp on a dyno or time on a 1/4 mile run if both wheels weigh the same............Thanks
[Modified by NightHawkC5, 10:53 PM 1/12/2003]
Old Jan 12, 2003 | 02:03 PM
GZERO's Avatar
Default Re: wheel size affecting whp (NightHawkC5)
your HP doesn't change, your gearing does (if the tires are larger/smaller in diameter), IF the wheels weight the same and the tires diameter are the same, the 1/4 mile run would be the same.
if the wheels weight the same, then you need to ask yourself if the rim/tire combo weights more or less than the 14 rim/tire combo you had before and if the diameter are larger or smaller as well
Old Jan 12, 2003 | 02:22 PM
Default Re: wheel size affecting whp (GZERO)
thanks
Old Jan 12, 2003 | 02:29 PM
10K2HVN's Avatar
..and also the tire size affects your grip as well...for 17's you would usaull go 40-series..which would be better for the turns but for the launch could give you a little more wheel hop...but the fat sidewalls for the 65 on 14's would exsorb (spelling?) the escaping energy from the spining wheels...
Old Jan 12, 2003 | 06:54 PM
threatcon13's Avatar
New User
Default Re: wheel size affecting whp (10K2HVN)
im not 100% sure..but i do recall there being a thread on this before...and it was stated that a bigger tire/wheel combo...even weighing the same as the smaller combo..would affect quarter mile times negatively.
my94d16y8coupe
Oct 2, 2011 03:29 PM
ozh_hawaiian
Jul 19, 2010 01:17 PM
myhondaaccord03
Mar 3, 2008 07:58 PM
davidh_125
Mar 10, 2003 06:22 PM
Rhythm Racer
84
Feb 7, 2003 09:28 AM
