Wheel offset for 16s
Old Oct 25, 2002 | 02:39 PM
b00stn's Avatar
Default Wheel offset for 16s
Car will be lowered with Tein adjustables to about 1.75 inches and camber will be adjusted to 0 front and rear with Ingalls. I am going to be running 16x7 wheels with 205/45/16 tires. Should I have a 45mm offset or 40 mm offset with a set of Rota Slipstreams?
Old Oct 25, 2002 | 04:34 PM
b00stn's Avatar
Default Re: Wheel offset for 16s (b00stn)
Bump. I just want to make sure I get the right offset and dont end up rubbing when I hit bumps.
Old Oct 25, 2002 | 04:42 PM
cyman83's Avatar
im pretty sure its 42-43mm offset. i have a 40mm offset on my 16x7 rim, and i rub all the time.
Old Oct 25, 2002 | 04:53 PM
b00stn's Avatar
Default Re: Wheel offset for 16s (cyman83)
how low are you?
Old Oct 25, 2002 | 06:35 PM
b00stn's Avatar
bump
Old Oct 26, 2002 | 09:21 AM
b00stn's Avatar
Bump. Anyone? I need to know by monday.
Old Oct 26, 2002 | 12:46 PM
b00stn's Avatar
ttt
Old Oct 26, 2002 | 02:13 PM
qcoffey's Avatar
You definitely want to stick to a 43 to 45 offset for your wheels especially if they are of the 16x7 variety. I run an 18x7 Ro-ja with a 215/35/18 falken fk451 on my '99 Si for the shows. I drive my car to every show and it is probably lowered in the neighborhood of 2.25-2.5 inches. The Ro-ja's are a 45 offset and the car does not rub a bit. To answer your tire question in your other post, I would recommend the Falken fk451. You can get them in a 205/45/16 or 215/40/16(the 215will give a wider appearance and more contactpatch). I ve travelled to approximately 10 shows this summer and have logged over 20k miles on my fk451 and I still have two that are in good condition (replaced front two, hard driving doesn't help treadlife.)
Old Oct 26, 2002 | 03:58 PM
prr's Avatar
prr
Default Re: Wheel offset for 16s (qcoffey)
I got mugen rg 16x7 with an offset of 43, and they fit great.
Old Oct 26, 2002 | 04:29 PM
b00stn's Avatar
Great info I am going with the 45mm offset slipstreams then. That is also great about the tires. You dont think that the wider size will causing any rubbing? I love the look of the wider tires but was kinda worried about the width.
thisguyhere
Honda Civic (2001 - 2005)
16
Jun 11, 2009 08:15 AM
JunIntegra
Jan 24, 2004 11:20 AM
93egsi
Jun 14, 2003 05:28 PM
MRDC2
Feb 21, 2003 05:33 PM
Ohlias
Sep 26, 2002 05:26 PM
