Wheel move when tugged
Old Dec 6, 2003 | 08:35 PM
Essence of Chicken's Avatar
Default Wheel move when tugged
I tugged on driver side wheel and I can hear it click somewhere, even moved a little (about 10-15mm tugging on the 12 o clock of the wheel). The thing is I dont know what it is or the seriousness of it. The lug nuts are tight and everything is torqued down. Only problem is that I have a broken rear motor mount, and the bolt holding it the mount is only half way in. Does anyone have any experience with this or perhaps help me to identify the problem?
Much thanks
Old Dec 6, 2003 | 09:30 PM
martini's Avatar
Default Re: Wheel move when tugged (Essence of Chicken)
take the wheel off and tug on the hub, see if you can tell.
It could be some loose suspension bolt, but chances are, it's your wheel bearing.
Old Dec 6, 2003 | 10:08 PM
Safe to drive? Safe to autox?
Old Dec 6, 2003 | 10:19 PM
BTW I recently loosen my axle, could it be that I did not properly reset the axle? Could that cause the wheel movement?
Old Dec 8, 2003 | 07:55 AM
Old Dec 8, 2003 | 10:48 AM
martini's Avatar
Default Re: (Essence of Chicken)
your wheel bearing might not be torque down properly.
you most likely won't pass tech inspection at an autox with a wheel like that. you can drive on it, but I wouldn't...at least not for long.
Old Dec 8, 2003 | 11:37 AM
doublejz's Avatar
Default Re: (martini)
check like inner tie rod or balljoint
Old Dec 8, 2003 | 11:48 AM
Perfectionist's Avatar
Upper ball joint is worn, possibly, from your description.
Old Dec 18, 2003 | 10:34 PM
Fixed... just a Loose bolts.
Old Dec 18, 2003 | 11:21 PM
Don Napier's Avatar
Import Alliance
It is nice sometimes when it is just something easy to fix.
Xvisor
Honda Ruckus and Scooters
Jun 27, 2018 08:23 AM
ITRDC2R
Jun 1, 2007 05:43 AM
cmyrex
Nov 14, 2006 08:28 AM
DEVIN22CBR
Honda Motorcycles
Aug 1, 2004 09:45 AM
DavidGSR
Aug 20, 2001 10:53 AM
