what's wrong with my tranny?
my car starts up fine but when i put it into 1st gear, all it does it grind. the car moves but barely. it's not driveable. 2nd & 3rd is the same. can anyone tell me what the problem is? fucked up bearing/gears?
there's about 45K miles on the tranny. i got this clutch:
http://store.yahoo.com/twincam....html
pressure plate is fine.
Sounds like it could be the TOB, clutch fork, slave cylinder or disk itself.
Try pulling the shield off to see if you see any debris in there..
In my 92 Hatch Si D16 sohc vtech I have the same clutch as unjockable....The only difference is that it grinds when I go into reverse. I'm hoping it's not the tranny...Im right with you unjockable. Ha. Same question...Is it the tranny?
Pull it off and find out.
More than likely, you ate a clutch disk. Sounds like it. If it won't go into gear, it's either the disk, the moveing parts that move the pressure plate, or your flywheel bolts backed out.
I saydisk. Only takes 35 minutes to take the tranny off. Pull it!
Stick
Stick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tim the Stick »</TD></TR><TR><TD CLASS="quote">Pull it off and find out.
Stick</TD></TR></TABLE>
should i just go buy a new clutch? do you think it fucked up my tranny? that's the thing i really want to know. rather buy a clutch then a tranny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maztur »</TD></TR><TR><TD CLASS="quote">If it goes into gear when car is OFF, then most likely your tranny is fine.</TD></TR></TABLE>
That is why I asked that above to see if the internals in the transmission are good.
When the car is on, the clutch, main shaft and counter shaft are spinning and the synchros are needed to match in order to put it into gear.
TOB = Throw Out Bearing. When you push on the clutch that is what pushes on the pressure plate to disengage the clutch plate.
I would pull open the tranny and such and inspect it. Sounds like the clutch or the throw out bearing is toast.
maxheat
15
Jan 5, 2005 02:23 PM
what's wrong with it? is it the clutch or tranny?
