whats needed to go obd1 everything
Old Jan 17, 2002 | 05:52 PM
seek167's Avatar
Default whats needed to go obd1 everything
i got a 99 dx with a b18c5, i'd like to know everything that i need.i know i need a wire harness a p28 and injectors . what size injectors do i need. anything else
thanks
Old Jan 17, 2002 | 07:44 PM
rainforest's Avatar
Default Re: whats needed to go obd1 everything (seek167)
All d and b series injectors are 240cc's, and you dont need new injectos the obd1-2 are saterated just have different plugs(just match the colors up). you will need to rewire your dist for no crank angle sensor. you Will need to take out that secondary o2 sensor .
Old Jan 17, 2002 | 09:43 PM
1 2 NV's Avatar
just reprogram a 92-95 VTEC ECU with a R program and get a jumper harness. the OBD1 ECU just lacks the extra sensors.
Old Jan 17, 2002 | 10:33 PM
salbaje's Avatar
if you need any parts let me know i can get them all.
Old Jan 18, 2002 | 06:34 AM
kenji's Avatar
Default Re: whats needed to go obd1 everything (salbaje)
All you need is an OBD2 to OBD1 ECU conversion harness and an OBD1 ECU. Both of which I can take care of for you.
There is no need to switch anything else (e.g. injectors, distributor, etc.).
The harness is a plug and play install and I have a couple of chipped P28 ECUs that will run your setup VERY strong. Just ask B18C5-EH2. He has a JDM ITR swap in his Civic with my ECU and is making some pretty impressive power considering his mods.
I can offer you a package deal if you get the ECU and harness at the same time.
Please email me at kenji211@tampabay.rr.com for more info.
-kenji
[Modified by kenji, 7:36 AM 1/18/2002]
smokeyjpn221
Apr 21, 2010 06:29 PM
Unknown Racing
Dec 30, 2008 11:49 PM
hatch96y7
Jun 19, 2007 03:26 PM
SoyMilk
May 27, 2007 04:19 PM
pane93civhb
Feb 15, 2005 12:35 PM
