Whats crankwalk?
Old Jan 29, 2003 | 06:40 PM
dallasyoung's Avatar
Default Whats crankwalk?
The title says it all...what is it? I always hear about it from turbo dsm's but I dont know what it is. PLEASE HELP!
Old Jan 29, 2003 | 06:58 PM
vw-honda-hatches's Avatar
Default Re: Whats crankwalk? (dallasyoung)
thrust bearing going bad i beleive? Usually only happens on certain years (dont remember years) and before 50,000 miles.
Old Jan 29, 2003 | 07:13 PM
Default Re: Whats crankwalk? (vw-honda-hatches)
Thrust bearing?!
Old Jan 29, 2003 | 07:20 PM
KS-R's Avatar
I believe it's thrust washers for Honda motors.. It's a common issue with Talon/Eclipse motors... Mainly the 95+ motors...
I'm not 100% sure of the cause, but I've heard of excessive clutch pressure plate pressure could be a cause.. What happens is the crank is able to move back and forth..
Here's a link that might help you understand.
http://www.magnusmotorsports.com/crankwalktheory.htm
[Modified by KS-R, 8:20 PM 1/29/2003]
Old Jan 29, 2003 | 07:24 PM
kyle h.'s Avatar
Default Re: Whats crankwalk? (KS-R)
in short the crank moves back and forth. it rocks in place. where it is only supposed to spin.
Old Jan 29, 2003 | 07:33 PM
Kataku2K3's Avatar
Default Re: Whats crankwalk? (kyle h.)
Yup and if you get too out of spec then damage to the crank and block can occur... You'll usually notice it just through how the clutch engages... If it feels as though over time you have to set the clutch pedal in farther and farther, that is a sign of the thrust washers going out... Whey my friend spun his B16's thrust washer it was beaten around his block which cracked the bottom side of the pistons and destroyed the entire crank/block... Latez
Old Jan 29, 2003 | 07:34 PM
Whats so bad aboutt he crank moving back and forth? What does it damage?
Old Jan 29, 2003 | 08:26 PM
dmotoguy's Avatar
the block, its cause is unknown.. normally in 95-97 4g63, sometimes 98-99 too
Old Jan 29, 2003 | 08:41 PM
areyouasian's Avatar
its when the crank slides back and fourth, its bad for the bottom end when you have crank walk cause it can damage the crank. usually results when thrust washers go bad but crank walk is pretty rare in hondas unless you tore apart your bottom end and didnt install the thrust washers in properly during reassembly.
Old Jan 30, 2003 | 03:19 AM
Default Re: Whats crankwalk? (areyouasian)
Con someone explain to me what a thrust washer is? lol thanks!
Old Jan 30, 2003 | 05:10 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
LOL, um, well when you have a balanced peice of metal spinning at about 7000 rotations per minute, it needs to be going in the same direction, and not all over the place. If the crank is spinning out of spec, its going to make for a horific end
Old Jan 30, 2003 | 06:11 PM
Default Re: Whats crankwalk? (SIXTYdashONE)
Oh ok thanks...but whats a thrust bearing?
Old Dec 5, 2003 | 12:06 PM
chris@allmotor.net's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dallasyoung &raquo;</TD></TR><TR><TD CLASS="quote">Oh ok thanks...but whats a thrust bearing?</TD></TR></TABLE>
the bearing under the washer...duh...
t_can
Engine Machining & Assembly
27
Jun 27, 2017 10:23 AM
cityofcaterpillars
Aug 20, 2016 02:30 AM
teg_95
Oct 13, 2009 11:51 PM
92 RHD EG
Sep 13, 2007 08:52 AM
EsTiLo
May 18, 2003 08:25 AM
