Help Crank walked
Old May 16, 2003 | 05:54 AM
EsTiLo's Avatar
Default Help Crank walked
Ok I need help...
Lately my car dies when I am shifting in low rpm, mostly when I pushed the clutch...
So I tought it was a clutch or something like the fork or the throwout bearing. today I checked it and it was fine...
Somehow I notice the crank pulley is moving when a friend of mine pushed the clutch. Can it be my trust bearing is broken or something? If It did what can happen and howmuch damage could it create and how much to fixed...
Thanks guys
Old May 16, 2003 | 07:03 AM
Spade's Avatar
Default Re: Help Crank walked (EsTiLo)
Get a new engine.
Old May 16, 2003 | 07:08 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EsTiLo &raquo;</TD></TR><TR><TD CLASS="quote">Somehow I notice the crank pulley is moving when a friend of mine pushed the clutch. Can it be my trust bearing is broken or something?
Yep, probably a bad thrust bearing. You'll have to tear it down to inspect the damage done. Doesn't sound good though.
Old May 16, 2003 | 11:49 PM
EsTiLo's Avatar
damn sucks... getting B20 then now.
Oh ya will all the mount will fits on the B20 from B18C? such as altenator mount and AC?
Old May 17, 2003 | 12:17 AM
4DeepCivic's Avatar
Default Re: (EsTiLo)
yeps.. all mounts fit
Old May 17, 2003 | 12:39 AM
10K2HVN's Avatar
maybe you should consider a re-sleeved B18A/B block instead of a B20......
Old May 17, 2003 | 06:17 PM
EsTiLo's Avatar
Thanks guys for the info
10K2HVN: Why you consider re-sleeved B18A/B instead B20?Any reason for that?
Old May 17, 2003 | 06:29 PM
Blaze45's Avatar
Brrraaaap!
7mm vs 9mm sleeves the B20 has more trq tho.
Blaze
Old May 18, 2003 | 12:15 AM
10K2HVN's Avatar
..because the B18A/B are pretty much the same except the bore (sleeves). if you get a B20 then youll spend $700~$1100 on it, but a B18A/B is about $100~$600.. the money that you save on the B18A/B can be spent on *new stronger sleeves* that can be bore anywhere from 81mm to 87mm (84mm if you want the same as B20. 87mm is not as streetable)..
http://www.rsmachines.com/blocks.html
http://goldeneaglemfg.com/sleeves.htm
http://www.lasleeve.com/
Modified by 10K2HVN at 1:50 AM 5/18/2003
Old May 18, 2003 | 08:25 AM
EsTiLo's Avatar
Cool let me think about it and see ...
My GSR now running so good till this trust bearing fell out after I races a WRX. (still won)
jrubenis1
Apr 3, 2013 06:59 AM
thedudefromjerz
Aug 3, 2008 07:57 PM
VVV
Feb 16, 2007 02:36 AM
paulwithap
May 22, 2006 08:58 PM
Gabe_
Dec 28, 2003 12:12 PM
