Whats the compression ratio for this setup!!
Hey tech's i need help. I am going to buy a block from my friend and this block is a 95 b18b with b16a pr3 pistons in it on ls rods and i need to know what the compression ratio would be if i had a 95 ls head on it. thanks in advance!
aprx. 11.1 :1 considering you piston to deck is .020 and your using stock head gasket also that is with a stock 45cc chamber and 89mm stroke hope it helped you out
lv2exl8
Jun 27, 2006 09:03 PM
lv2exl8
Jun 24, 2006 09:57 AM
