whats this code #1
Old Mar 15, 2003 | 04:51 PM
xxthabest1xx's Avatar
Default whats this code #1
i need to know what does the code number 1 mean oxygen content. what is it need help, thats what the car is shooting out. b18 integra
Old Mar 15, 2003 | 04:52 PM
raene's Avatar
Default Re: whats this code #1 (xxthabest1xx)
Oxygen sensor
Old Mar 15, 2003 | 05:38 PM
eg6ajk's Avatar
Default Re: whats this code #1 (raene)
Code Meaning
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
Old Mar 15, 2003 | 06:05 PM
OGEF9ER's Avatar
Default Re: whats this code #1 (eg6ajk)
I have the same problem. I changed the 02 sensor to a bosch and it still is constantly on. I am getting tired of seeing it.
Old Mar 15, 2003 | 06:06 PM
.RJ's Avatar
.RJ
Default Re: whats this code #1 (OGEF9ER)
Put an OE honda plug in. Thats your problem.
98tegLSvtec
Jul 31, 2011 01:33 PM
Laz's EP
22
Feb 22, 2010 12:09 AM
93b20z
May 18, 2009 04:59 PM
CustomX113
11
Sep 1, 2006 01:27 PM
Phrost
May 29, 2006 02:44 PM
