what would you do?
Old Aug 24, 2006 | 03:57 PM
DARKTEG_'s Avatar
Default what would you do?
this is what i've got so far, just wondering what you would do next,and why, and if your going to say turbo, don't even reply cause i'm not doing it!
b18b obd1
Act stage 4 clutch, pressure plate, and release bearing
AEM Cold air intake
AEM fuel rail
AEM tru time pulleys
B&M fuel pressure regulater, with gauge
Crower stage 1 cams
DC Sports 4 2 1 one piece header
Golden eagle adjustable cam gears
GSR obd2 injectors
GSR transmission Phantom Grip LSD with LS 5th gear
Hondata intake gasket
Mr. Gasket distributor cap and rotor button
Nopi brand - lightweight flywheel
Prothane engine mount bushings
Skunk 2 intake manifold
Unorthadox Crank pulley
Old Aug 24, 2006 | 06:24 PM
MR EK's Avatar
short shifter, and engine componets!
rods pistons sleve head studs etc.............build up a stringer motor so u if u ever wanna sqeesze NITROUS or go turbo your engine will handle it!
Old Aug 24, 2006 | 06:38 PM
Heretic:Si's Avatar
Default Re: what would you do? (gonk_1)
ls-vtec is something to think about
Old Aug 25, 2006 | 11:51 AM
unknown0001's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gonk_1 &raquo;</TD></TR><TR><TD CLASS="quote">this is what i've got so far, just wondering what you would do next,and why, and if your going to say turbo, don't even reply cause i'm not doing it!
b18b obd1
AEM Cold air intake
AEM fuel rail
Crower stage 1 cams
GSR obd2 injectors
raise the compression ratio and add some individual throttle bodies light flywheel and a higher Final Drive for your transmission
Old Aug 26, 2006 | 12:41 AM
Enzo Speed's Avatar
Default Re: what would you do? (Mr.RHTuner)
Milking power from an NA motor is a pretty set procedure. If it were me, my priorities would be as follows:
1. V-tec conversion
2. Intake
3. Header
4. Exhaust
5. Clutch/flywheel
6. Cams
7. Intake manifold/throttle body
8. Headwork (port work/valve job/milling)
9. Accessory underdrive pullies as a last resort
That's about all you can do as far as power goes. Add some higher flowing injectors and you'd be set.
DARKTEG_
Sep 23, 2006 09:40 AM
DARKTEG_
Sep 15, 2006 02:23 PM
DARKTEG_
Aug 24, 2006 09:48 PM
DARKTEG_
Aug 24, 2006 04:17 PM
