what would cause map, tps, iacv, vss and o2 sensor to all error
Old Aug 8, 2005 | 09:22 AM
doublejz's Avatar
Default what would cause map, tps, iacv, vss and o2 sensor to all error
what would cause the map, tps, iacv, vss and o2 sensor to all error. Is there a common ground or wire between them that could be messed up? If i unhook the map or iacv sensors the car will shut off. so the sensors are doing something. the tps sensor really doesnt make a difference if it is connected or not. It hesitates really bad when i give it gas. when it gets hot it runs worse. I did have the vss wires switched is there a fuse or something somewhere that could have blown???
Old Aug 8, 2005 | 09:37 AM
Redline130's Avatar
Default Re: what would cause map, tps, iacv, vss and o2 sensor to all error (doublejz)
Sounds like a grounding problem. Do you have the thermostat ground on?
Old Aug 8, 2005 | 09:40 AM
doublejz's Avatar
Default Re: what would cause map, tps, iacv, vss and o2 sensor to all error (Redline130)
yep
Old Aug 8, 2005 | 10:37 AM
Seriph's Avatar
Hmm... Check the schematics. See if all those sensors share a ground. If they do, you've found your problem. Check continuity between the ground wire on the sensors to the negative terminal of the battery.
Old Aug 9, 2005 | 04:23 AM
doublejz's Avatar
Default Re: what would cause map, tps, iacv, vss and o2 sensor to all error (Seriph)
not a ground problem.......
todd whaley
Nov 18, 2013 02:10 AM
Veggie Man
Sep 25, 2012 02:49 PM
cleanazcoupe
Engine Management and Tuning
Jul 8, 2009 09:28 PM
fullraceacura
Mar 30, 2005 06:15 PM
Morhpeous
May 24, 2004 07:00 PM
