What SOHC oil pans are interchangeable?
Old Jul 7, 2006 | 02:56 PM
hondaguyef's Avatar
Default What SOHC oil pans are interchangeable?
Just curious as to which (If any) are interchangeable?
Example: D16a6 oil pan on D16y8 shortblock?
Thanks.
Phil
Old Jul 8, 2006 | 06:54 AM
hondaguyef's Avatar
Default Re: What SOHC oil pans are interchangeable? (hondaguyef)
Anyone?
Old Jul 8, 2006 | 06:56 AM
NJcoupe's Avatar
I know D16Y5,D16Y7, & D16Y8 are interchangeable, They are all cast aluminum besides the D16Y7, which is steel like all other oil pans.
Old Jul 8, 2006 | 07:00 AM
hondaguyef's Avatar
Default Re: What SOHC oil pans are interchangeable? (dxcoupe.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dxcoupe. &raquo;</TD></TR><TR><TD CLASS="quote">I know D16Y5,D16Y7, & D16Y8 are interchangeable, They are all cast aluminum besides the D16Y7, which is steel like all other oil pans.</TD></TR></TABLE>
Yeah, I need steel pans. I have a feelling Y7 pans are going to be hard to find . Thanks bro.
Old Jul 8, 2006 | 10:17 AM
HiProfile's Avatar
Z6/A6 are usally the same parts fitment, and I know a y8 pan will not fit a z6. The ends have a different size radius for the seal - huge gap on either side of the crank area. I'd assume a y7 would fit a y8, since mostly everything on a y7 is the same as a y8. Not 100% sure though, but I will have a y8 & y7 pan next week to compair.
I may have 2 y7 pans neext week & an extra y8 pan. I may be able to get away with an alum pan for my turbo fittings, as I can easily tap the 1/8" thick walls. Its the angle I need which is discouraging.
Old Jul 9, 2006 | 06:55 AM
hondaguyef's Avatar
Default Re: What SOHC oil pans are interchangeable? (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">Z6/A6 are usally the same parts fitment, and I know a y8 pan will not fit a z6. The ends have a different size radius for the seal - huge gap on either side of the crank area. I'd assume a y7 would fit a y8, since mostly everything on a y7 is the same as a y8. Not 100% sure though, but I will have a y8 & y7 pan next week to compair.
I may have 2 y7 pans neext week & an extra y8 pan. I may be able to get away with an alum pan for my turbo fittings, as I can easily tap the 1/8" thick walls. Its the angle I need which is discouraging.</TD></TR></TABLE>
Thanks for the info. LMK, if you want to sell one of those Y7 pans.
Phil
Old Jul 10, 2006 | 04:29 PM
turboteener's Avatar
Banned
The A6 pan will have some interference with the Y8 B pipe. It will rub on the collector. I know the Z6 pan may have some more clearence.
Old Jul 11, 2006 | 08:43 PM
FIGARILA's Avatar
Default Re: (turboteener)
are you saying the z6 pan is different then say an a6 pan???
Old Jul 12, 2006 | 07:27 AM
NoLongerNA's Avatar
I know an A6 wont fit on a Y7 bottom end.
Old Jul 12, 2006 | 08:36 AM
Katman's Avatar
Y8 will fit an A6 block.
I have a rebuilt A6 short block with Y8 pan sitting in my garage.
Fantastic420
Mar 2, 2011 06:05 PM
THEDirtyDseriesWOOT
Dec 17, 2006 04:46 PM
boostincoupe
Feb 2, 2006 12:56 PM
I Have an STD
14
Dec 19, 2005 06:34 PM
rasinhell
11
Feb 8, 2005 10:25 AM
