What size to re-thread D block threads
Old Aug 10, 2006 | 06:15 PM
1991civicsi's Avatar
Default What size to re-thread D block threads
While I was installing my clutch I accidentally stripped the threads on the engine block of my D16A6.
The bolt (size 12x65) that connects the transmission to the block (as pictured numbered 22), is just spinning. So, I was just going to drill it out and tap it a larger size, but I was wondering if anyone knows what size I should use.
Thanks
Old Aug 11, 2006 | 05:37 AM
Default Re: What size to re-thread D block threads (1991civicsi)
Does anyone have any suggestions how I can fix this?
Old Aug 11, 2006 | 08:49 AM
unknown0001's Avatar
check out m12x1.25....thats the thread pitch of the bolt that secures the engine and tranny together.
Why not just buy the correct tap kit with the size I listed and try to slightly re-tap the threads? you might be able to correct them.
if not then try to re-drill with a larger diameter bolt and re-thread it(but not too large as it might weaken the mounting area
Old Aug 11, 2006 | 02:02 PM
jhota's Avatar
use a Helicoil, man.
http://www.emhart.com/products/helicoil.asp
Old Aug 12, 2006 | 10:22 PM
CovertFI's Avatar
Default Re: What size to re-thread D block threads (jhota)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jhota &raquo;</TD></TR><TR><TD CLASS="quote">use a Helicoil, man.
http://www.emhart.com/products/helicoil.asp</TD></TR></TABLE>
helicoil is what you need to use, they will with stand anything, I have either 3 or 4 on my turbo manifold.
Old Aug 15, 2006 | 07:23 PM
Default Re: What size to re-thread D block threads (CovertFI)
Im using this product for the first time, and I was hoping someone would let me know if Im ordering the right item.
So, I was going to get the Heli-coil thread repair kit part #HCMKF 5405-12 (M12x1.25)
Is this the correct part to re-install a M12x1.25 bolt, or
is this to install a M12x1.25 Heli-coil to be installed with a smaller inside diameter (eg. M10x1.25) bolt?
Oh yeah, Im going to install a new M12x1.25 bolt and discard the stripped bolt.
LMK Thanks
Modified by 1991civicsi at 12:56 PM 8/16/2006
Old Aug 16, 2006 | 11:57 AM
93lsv_turbo
Feb 9, 2012 07:45 AM
webbs2jzgte
Jan 24, 2009 08:38 AM
Top Ramen
Mar 31, 2006 12:57 PM
brinks
May 19, 2004 03:39 PM
