what is this sensor called
Old Dec 8, 2003 | 04:24 PM
noble4ws's Avatar
Default what is this sensor called
i need to know exactly what part number 21 is, cause i think that is on the firewall in my 92 prelude 4ws, this is a pic of a 95 h22 that i put in, thanks
Old Dec 8, 2003 | 04:26 PM
LudeyKrus's Avatar
IACV?
It should say on that site you're lookin at!
Old Dec 8, 2003 | 04:29 PM
h22 civic's Avatar
Default Re: (LudeyKrus)
map
Old Dec 8, 2003 | 04:37 PM
KOALA YUMMIES's Avatar
Default Re: (h22 civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 civic &raquo;</TD></TR><TR><TD CLASS="quote">map</TD></TR></TABLE>
Yep.
Old Dec 8, 2003 | 04:41 PM
noble4ws's Avatar
would it have been on the firewall with the h23, cause there was no plug there for it, but something very similar if not the same is on the firewall, so would i be alright just putting a block off plate there
Old Dec 8, 2003 | 09:11 PM
noble4ws's Avatar
ttt
Old Dec 8, 2003 | 09:27 PM
Erik_Pb_Foot's Avatar
New User
Default Re: (noble4ws)
confused... what exactly are you trying to do?
if you swapped in an h22, does the map reside on top of the tb like in the pic? if that's the case then you need to hook your vacuum up to it instead of the map that was/is on your firewall... or at least thats what i think you should do
Old Dec 8, 2003 | 10:05 PM
chrisCNL's Avatar
Default Re: (Erik_Pb_Foot)
map senor alright.
Old Dec 8, 2003 | 11:00 PM
iam7head's Avatar
Default Re: (chrisCNL)
map sensor fo sho
dont forget to get the o ring for it
Old Dec 9, 2003 | 07:46 AM
aw1234dude's Avatar
Default Re: (iam7head)
Some of the older hondas have the map sensor mounted on the firewall instead of having them mounted on the throttle body. I believe older civics, accords, and maybe early preludes did. The ones mounted on the firewall look slightly different from the top mounted throttle body ones but they work exactly the same way. Just mount it somewhere on the firewall and run a vac line to it.
Old Dec 9, 2003 | 07:47 AM
bryan305's Avatar
Default Re: (aw1234dude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aw1234dude &raquo;</TD></TR><TR><TD CLASS="quote">Some of the older hondas have the map sensor mounted on the firewall instead of having them mounted on the throttle body. I believe older civics, accords, and maybe early preludes did. </TD></TR></TABLE>
and 2nd gen integras
Old Dec 9, 2003 | 06:09 PM
noble4ws's Avatar
so im fine with using the one on the firewall, i can just put a block off plate on there, thanks guys
Old Dec 9, 2003 | 06:19 PM
IN VTEC's Avatar
Just leave the old MAP sensor on the TB.
Use a MAP sensor from a '88 to '91 Honda Civic. I just saw some in the Classifieds.
Old Dec 9, 2003 | 07:19 PM
Jim Truett's Avatar
Default Re: (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Just leave the old MAP sensor on the TB.
Use a MAP sensor from a '88 to '91 Honda Civic. I just saw some in the Classifieds.</TD></TR></TABLE>
If your state conducts an underhood inspection for emissions testing, this may not pass. You can completely remove the stock MAP sensor and lenghten the wires to connect it to the TB mounted MAP. Cover the wires with a piece of split-loom, and the average tech won't know the difference.
Old Dec 9, 2003 | 09:25 PM
noble4ws's Avatar
thanksk guys
tensaiwung
Apr 28, 2011 05:38 AM
spoink
Dec 7, 2005 10:26 AM
dan4h22a
May 31, 2005 06:00 AM
servion
Mar 19, 2003 04:38 PM
servion
Jun 17, 2002 11:07 AM
