what to plug o2 sensor hole with?
Old Sep 23, 2002 | 05:49 PM
juniordc2's Avatar
Default what to plug o2 sensor hole with?
i read this somewhere but I can't seem to find it now.. what do I cover up the hole in the cat with then I remove the o2 sensor? i think it was an oil dran bolt, but I want to make sure. thanks
Old Sep 23, 2002 | 06:07 PM
enhancedCL9's Avatar
Default Re: what to plug o2 sensor hole with? (dc2gsr94)
Yah i did the same! Just any kind of Bolt will work fine.
Old Sep 23, 2002 | 08:51 PM
TimoneX's Avatar
New User
Default Re: what to plug o2 sensor hole with? (thizguy)
If you use one of them magnetic oil drain plugs it will catch all the tiny metal fragments before they go BLASTING out the back of the exhaust and injure some innocent pedestrians!
J/K I couldn't resist.
Old Sep 23, 2002 | 09:37 PM
dustin's Avatar
Default Re: what to plug o2 sensor hole with? (TimoneX)
Honda oil drain bolt is not the right size. The thread width is correct but the diameter is wrong.
Old Nov 30, 2003 | 08:27 PM
roydogg's Avatar
Default Re: what to plug o2 sensor hole with? (dustin)
So what size bolt fits? ANd does it make any difference with or without a 02 sensor?
Old Dec 1, 2003 | 03:37 AM
crxste's Avatar
Default Re: what to plug o2 sensor hole with? (roydogg)
There's a company in the UK called BTB exhausts who sell both mild steel and stainless steel 02 bungs, they're about $5 each
Old Dec 1, 2003 | 07:19 AM
IN VTEC's Avatar
M18x1.5
All oxygen sensor bosses are the same. Domestic and import.
Old Dec 1, 2003 | 08:08 AM
Muckman's Avatar
Moderator in Chief
Default Re: what to plug o2 sensor hole with? (IN VTEC)
7/8" head
Old Dec 1, 2003 | 10:08 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
i've used a radiator fan thermoswitch couple different times. same size. if you have one laying around works just as good as a bolt.
enriquez2000
Dec 23, 2011 05:49 PM
killahatch
10
May 6, 2009 07:33 PM
unrefined7
12
Jan 3, 2006 04:36 PM
Art Vandeleigh
Mar 31, 2003 01:30 PM
