What paint to use on bolts/nuts?
Old Nov 19, 2006 | 10:01 PM
WhiteOnRice's Avatar
Default What paint to use on bolts/nuts?
If I let rustolem enamel (from a can) dry on bolts/nuts for like 3 days, will it be strong enough and not come off with a socket? What about on control arms/tie rods?
I used this (75% paint, 25% mineral spirits):
Old Nov 19, 2006 | 10:09 PM
umop-apisdn's Avatar
Default Re: What paint to use on bolts/nuts? (fizix_skate)
Install, then paint.
Old Nov 19, 2006 | 10:38 PM
Not an option.
Does anyone know if enamel is durable enough? A buddy of mine is confident it is as long as it completely dries...
Old Nov 20, 2006 | 03:27 AM
Flashmn's Avatar
Default Re: (fizix_skate)
doubt it would hold.
Old Nov 20, 2006 | 04:49 AM
Furyof4's Avatar
Default Re: (Flashmn)
Why are you painting bolts? Just curious.
Old Nov 20, 2006 | 05:39 AM
mmuller's Avatar
Mad Scientist
Default Re: (Furyof4)
if you paint the bolts the paint is going to come right off when torquing them...and its going to look like poo.
you can get the bolts coated like most stock ones.
Old Nov 20, 2006 | 06:17 AM
Coated with what? What should I use? They are all wire wheeled and need some sort of coating to prevent rust...
Old Nov 20, 2006 | 06:43 AM
CAD plating for one.
Old Nov 20, 2006 | 08:26 AM
rtype11's Avatar
look around locally for metal coating products called black oxide, they sell kits to do it at home- or http://www.e-blacksolutions.com
Old Nov 20, 2006 | 08:31 AM
Furyof4's Avatar
Default Re: What paint to use on bolts/nuts? (rtype11)
It will be cheaper to buy all new then have them plated. Cad platers usually have a minimum price doesn't matter whether you give them 1 bolt or 100.
Old Nov 20, 2006 | 11:00 AM
stealthmode62's Avatar
Default Re: What paint to use on bolts/nuts? (Furyof4)
I use rustoleum primer that is supposed to prevent rust. It says you can spray "sound rusted parts" too, but I wire wheel, spray the primer, and then I've been using duplicolor engine enamal. Semi gloss black. Here's a pic of some **** I've been doing.
I actually don't spray the bolts until they're torqued.
Old Nov 22, 2006 | 06:30 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Furyof4 &raquo;</TD></TR><TR><TD CLASS="quote">It will be cheaper to buy all new then have them plated. </TD></TR></TABLE>
Well the rustoleum paint was $7 and I probably won't even use 1/4 of it. All bolts new over the hood would probably cost $300. I hope it works.
Old Nov 27, 2006 | 12:42 PM
Just to let you all know, Rustoleum only scrapes off minimally when torqueing bolts to 80 lbs. A little touch up with a foam brush and they look perfect.
Old Nov 27, 2006 | 01:24 PM
khmboostedeh2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fizix_skate &raquo;</TD></TR><TR><TD CLASS="quote">Just to let you all know, Rustoleum only scrapes off minimally when torqueing bolts to 80 lbs. A little touch up with a foam brush and they look perfect.</TD></TR></TABLE>
pics?
Old Nov 27, 2006 | 08:53 PM
Muckman's Avatar
Moderator in Chief
I agree. It would look much better and cheaper to buy new OEM bolts. Thats what I do.
Old Dec 1, 2006 | 12:18 PM
Cheaper, ha. No, buying new bolts is defiantely NOT cheaper. Wow... $7 for Rustoleum.
Old Dec 1, 2006 | 02:48 PM
Muckman's Avatar
Moderator in Chief
He said cheaper than plating...
Spray painted bolts will look mickey mouse.
I did it, didnt like it at all.
Old Dec 1, 2006 | 11:25 PM
Oh, I didn't use spray, I used roll-on paint with a foam brush. Consider how people use this paint for their whole car ($50 paint job), it looks good but needs to be touched up after torqueing. I'll post pics when I get a camera.
Old Dec 2, 2006 | 12:20 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
Powdercoat individual pieces?
Old Dec 4, 2006 | 04:47 PM
projectegr's Avatar
Default Re: (full Circling)
Make sure when touching up to get the entire head of the bolt. I did what you did a while back and ended up with rust eating through primer due to me missing difficult spots on the bottom of the bolts when touching up. Just a heads up but if you got it all it should be fine.
WKD DRGN
Mar 29, 2014 06:31 PM
1SlowSi
Mar 13, 2007 04:56 PM
taunt_spike
Feb 15, 2007 08:24 PM
k-series
Jan 23, 2006 08:05 AM
Nightscape
Mar 13, 2003 02:56 PM
