what no one knows how to fix this!?!?!!!!
i know asked this question alot but since no one will give me a straight answer or stop answering in question form im getting no where! So someone please just help me out. I have a 91 hatch dx with that dpfi set up (two injectors) well in my manual it says to run the car till it is warmed up and then pull one of the injector clips and go look at how far the idle droped then put it back in and pull the other one. but i pulled then both sepritly and each time it smote the motor!! so now what do i do? How big of injectors can i get for the stock ecu? what size are my injectors? thanks guys
I sounds like your injectors are working. Are you the one with the code 16? If so when does the light come on? (As soon as it's started, or after driving a while?)
[Modified by 4ghatch, 12:50 PM 1/12/2003]
As soon as i start the car is goes on
