what engine/wire harness will fit
Old Jan 8, 2003 | 10:34 PM
cr00klyn718's Avatar
Default what engine/wire harness will fit
what engine and wire harness will fit a 94 civic h/b cx with a b18c1(gsr engine) running a p28 chipped.....will a obd1 ex engine and wire harness work or only gsr engine and wire harness?
Old Jan 9, 2003 | 12:04 AM
Cnote's Avatar
Default Re: what engine/wire harness will fit (cr00klyn718)
Use either EX harness or GSR harness, both will work fine.(EX harness will need to be modified/added for IAB/butterflies)
Me personally I would use the GSR harness for the IAB problem AND RUN A P72(unless your using a single stage intake manifold). SO all you'll have to do is switch A20 to A17 to get your IAB hooked up.
Then Add A4,D6 to the strut tower harness.
[Modified by Cnote, 1:06 AM 1/9/2003]
Old Jan 9, 2003 | 04:48 PM
salbaje's Avatar
you can use any obd1 harness of course if you use a dx or cx harness you will need to add vtec wires and extend or add other wires. if you dont want to do that use the ex/si add knock or gsr
Old Jan 9, 2003 | 07:28 PM
Default Re: what engine/wire harness will fit (salbaje)
gsr one will be plug and play right.
CasperX
Mar 21, 2016 12:48 PM
crxjosh
Mar 1, 2010 11:04 PM
dthug
Aug 2, 2006 11:47 AM
Mugen112
Jul 12, 2005 09:25 AM
Reddog
Jul 1, 2002 11:40 PM
