what does the vacuum system provide the engine?
Old Aug 27, 2005 | 06:00 PM
pbink's Avatar
Default what does the vacuum system provide the engine?
I obviously have a lot to learn about some of the components of the internal combustion engine...
What the do the vacuum lines do? Multiple tasks across many components, I'm assuming, since so many different valves/components have vacuum lines running to them.
Old Aug 27, 2005 | 07:58 PM
m00nr0ck Si's Avatar
Default Re: what does the vacuum system provide the engine? (pbink)
well the motor pulls a vac. on
-the fuel pressure regulator
-brake booster
-egr(exaust gas recirculator)
-charcoal canister(pulls fumes from the gas tank into combustion chamber)
-pcv valve(pulls pressure from the crank case to keep from blowing piston rings etc....)
-and many other things depending on what car you have and what motor it has.
Old Aug 27, 2005 | 10:09 PM
pbink's Avatar
Default Re: what does the vacuum system provide the engine? (dorkoftheyear)
thx for the post ;]
Old Aug 28, 2005 | 11:25 AM
pbink's Avatar
so all vacuum comes from the cylinders?
Old Aug 28, 2005 | 11:32 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pbink &raquo;</TD></TR><TR><TD CLASS="quote">so all vacuum comes from the cylinders?</TD></TR></TABLE>
yeah
slamLOWnBANGIN
11
Feb 19, 2010 03:55 AM
cbags05
Jun 5, 2007 08:16 PM
Lost_clearance
Mar 25, 2007 07:38 PM
zumiez007
Nov 21, 2004 08:24 PM
Joon525
Jun 17, 2003 08:13 PM
