what to do with stripped o2 bung
Old Dec 4, 2008 | 02:10 PM
Charlie Moua's Avatar
Default what to do with stripped o2 bung
oem y8 head o2 bung is stripped slightly
what should I do?
1) jb weld the o2 sensor in the hole?
2) try to tap it
......a) if I do that does the header have to be taken off?
......b) how much pressure is applied to the tapper to make it thread?
Old Dec 4, 2008 | 02:55 PM
havok hybrid's Avatar
They make a 02 thread chaser. I would give that a shot.. You should be able to fix it .
Old Dec 4, 2008 | 07:40 PM
srmofo's Avatar
if its beyond repair, just stuff a plug in it and weld it in....then drill a hole an inch or 2 further down and weld another bung in
Old Dec 5, 2008 | 05:15 AM
for the o2 chaser.... where can i buy it?
also to use it, does the manifold have to be off the car?
Old Dec 5, 2008 | 10:40 AM
The have them at autozone.. Also know as a spark plug thread chaser .. (same threads)
you dont have to take the manifold off... its just exhaust right.
Old Dec 5, 2008 | 02:54 PM
uniseriate's Avatar
You just need Lisle part number 12230, Oxygen Sensor Thread Chaser.
You could also use the combination oxygen sensor / spark plug chaser, Lisle #20200. You can get that at amazon for five bucks and change.
Old Dec 5, 2008 | 03:10 PM
Ubertec's Avatar
Since it already stripped I say lay it down and give it some good lovin...dont forget lube
Old Dec 5, 2008 | 04:08 PM
BlakeJ53's Avatar
you need a 18 by 1.5 tap
Wazup
Aug 27, 2005 06:17 PM
phiberoptik
Jun 8, 2004 12:43 PM
iH8RICERZ
Mar 19, 2004 01:50 AM
