what are crush washers?
Old Oct 8, 2005 | 03:56 PM
RACEPAK's Avatar
Default what are crush washers?
hello everybody.
can you please tell me what are cruch washers and where do thay go?
thanks.
Old Oct 8, 2005 | 04:28 PM
NJIN BUILDR's Avatar
Default Re: what are crush washers? (RACEPAK)
Also known as sealing washers.They're used on brake lines and bolts with fluids or pressure behind them,like the oil pan drain bolt
Glenn.
B20TDC2's Avatar
crush washers are typically placed on the oil drain plug,
Old Oct 8, 2005 | 04:30 PM
redspiritguy's Avatar
crush washers are washers made out of aluminum. Whenever you tighten the bolt there on they crush making it seal very well. Honda uses them on alot of bolts on the engines and trans. anytime fluid will pour out when you remove a bolt, it will or should have a crush washer. (i.e. oilpan)
Old Oct 8, 2005 | 05:09 PM
projectTeG's Avatar
when torqued down they create seal seal between the bolt to prvent leaks...i.e your oil pan. they are one of the major causes of leaks, ppl dont think to replace them.
Old Oct 8, 2005 | 06:58 PM
Lewdin' Incognito's Avatar
Default Re: (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">when torqued down they create seal seal between the bolt to prvent leaks...i.e your oil pan. they are one of the major causes of leaks, ppl dont think to replace them.</TD></TR></TABLE>
......which is why you get one in the package when you buy your oil filter from Honda.
Old Oct 8, 2005 | 08:43 PM
drdisco69's Avatar
Default Re: (Lewdin' Incognito)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lewdin’ Incognito &raquo;</TD></TR><TR><TD CLASS="quote">......which is why you get one in the package when you buy your oil filter from Honda. </TD></TR></TABLE>
After you pay for it. It's not 'included' in the oil filter, the parts guy adds it in there. They get your $0.40, trust me.
Old Oct 9, 2005 | 02:13 AM
RACEPAK's Avatar
Default Re: (drdisco69)
Thanks everybody... i thought it was somthing else.
i my english is not the best...
oprac
10
Aug 8, 2007 08:05 PM
EikoU
Jun 12, 2006 08:14 PM
y0itzflip
Oct 11, 2005 05:12 AM
teewhy55
13
Dec 13, 2004 11:17 AM
megaman096
17
Dec 5, 2004 03:09 PM
