welding exhaust
Old Feb 15, 2006 | 12:22 PM
staticrex's Avatar
Default welding exhaust
just curious are there any drawbacks to welding your exhaust together rather than using the bolt's and flanges? any stress on anything? or is it ok to do?
Old Feb 15, 2006 | 01:23 PM
runeminaEF9's Avatar
Default Re: welding exhaust (staticrex)
by "welding exhaust" i would assume you mean welding the header to the catalytic converter, or to the rest of the exhaust if you dont have a cat. i've seen people do it before, but i wouldnt because the bolts and springs which are supposed to hold the header and exhaust together are there to provide flex. if your suspension bottomed out for instance, you could do more severe damage than just denting your header. i'm sure if you took it to an exhaust shop, they could weld in some flanges and hook it up for fairly cheap. exhaust systems NEED to have some type of flexibility to them, thats why you have rubberized exhaust hangers that stretch, so the exhaust can move around a little bit if it needs to. also, when you weld like that, it becomes PERMANENT till you cut it, so say goodbye to pulling your header or exhaust with ease.
Old Feb 15, 2006 | 02:52 PM
staticrex's Avatar
Default Re: welding exhaust (runeminaEF9)
well I can't get the flanges to get a good enough seal to stop the exhaust leak. I figured the next step would be to weld. as long as I had a flex pipe on my lower b pipe wouldn't that be enough to not hurt anything.?
Old Feb 15, 2006 | 06:32 PM
MyEVO8u's Avatar
gaskets?
Old Feb 15, 2006 | 06:52 PM
Default Re: welding exhaust (slvrcrxtuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slvrcrxtuner &raquo;</TD></TR><TR><TD CLASS="quote">gaskets?</TD></TR></TABLE> ^ make sure its the right size if you have one in there.
Old Feb 16, 2006 | 05:58 AM
staticrex's Avatar
well I am not an idiot. I have bought brand new gaskets, first at autozone, second at Honda, and then i doubled them up. And still nothing is working.
Old Feb 18, 2006 | 07:21 PM
ls vtech hatch's Avatar
i have apexi world sport and i dont think i would pay that much and then weld it together because one day i know il want something different and sum1 will want 2 buy it and no1 wants a welded exhaust
Old Feb 19, 2006 | 06:29 AM
sc4dr's Avatar
Default Re: (ls vtech hatch)
I've welded my exhaust like that before, due to crappy flanges that wouldnt seal. Its just wrong all the way around to<U> have </U>to do that. As long as you have a flex pipe, and a <U>quality weld</U>, you'll be okay. Just plan on keeping it for a while
y2kferari
Dec 6, 2006 11:43 AM
LSEGHATCH
Jun 29, 2006 09:40 AM
CTR-GSR
Nov 27, 2005 06:35 PM
alfaaay
Aug 8, 2003 12:46 AM
