Welding the Diff?!?!
Old Dec 12, 2003 | 09:46 AM
Burke's Avatar
Banned
Default Welding the Diff?!?!
Seen some ppl are going this and im building up a high hp SOHC. cant afford a quaife yet. So instead of peglegging it at the track i was thinking of just welding the diff. got some 22x8's too.
the only thing im worried about it snapping the stock axles with the welded diff. i know the open would put less stress on them and could increase their lifespan.
anybody have any experience with this and/or instructions on how excatly to weld it
Thanks
Burke
Old Dec 12, 2003 | 12:11 PM
Kendall's Avatar
I can't recommend doing this, if you're just looking for a short term fix until you can afford a Quaife, then just use a Phantom Grip. They wear out quickly, and don't do as good of a job as they claim to, but they do get the job done and don't do anything permanent to the differential. And if you do weld it, you would weld the spider gears.
Old Dec 12, 2003 | 04:37 PM
PupaScoopa's Avatar
Default Re: (dc231)
If the car will be running on drag slicks ONLY (not daily driver) and all you'll be doing is driving around the paddock at a track then you should be ok. You won't be putting tons of power into the axles just moving around the track; and when you do you'll be going straight. The tires should be flexible enough to slip when you make low-speed turns.
Old Dec 12, 2003 | 08:32 PM
Burke's Avatar
Banned
Default Re: (PupaScoopa)
thanks for the advise guys
i wont ever use a phatom grip, they suck and would just be a waste of money if you ask me
Old Dec 13, 2003 | 08:26 AM
Kendall's Avatar
Default Re: (Burke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burke &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the advise guys
i wont ever use a phatom grip, they suck and would just be a waste of money if you ask me</TD></TR></TABLE>
Exactly. Get a Genuine Honda LSD, or a Quaife.
Old Dec 13, 2003 | 12:40 PM
Burke's Avatar
Banned
Default Re: (dc231)
any more suggestions or advise??
Old Dec 14, 2003 | 12:02 PM
AzG35's Avatar
Default Re: Welding the Diff?!?! (Burke)
I believe its illegal to do at some tracks as well. I wouldn't recommend it, maybe only in a race car that goes in a straight line.
Old Dec 15, 2003 | 08:45 PM
Rtype16's Avatar
Default Re: Welding the Diff?!?! (AzSi22)
It is illegal at all race tracks. Welding the diff is extremely dangerous.
Old Dec 16, 2003 | 06:41 AM
Burke's Avatar
Banned
Default Re: Welding the Diff?!?! (Rtype16)
why is it illegal and so dangerous
thanks!
Old Dec 16, 2003 | 07:49 AM
Rtype16's Avatar
It is in every rule book out. Most tracks follow the NHRA standards for rules. Welding diffs can be dangerous becasue it will weaken the diff when you weld to it and if it ever gives parts and including the car can go pretty much anywhere.
Old Dec 16, 2003 | 08:02 AM
Burke's Avatar
Banned
must have missed that in the rulebook. guess ill go open for a while
Thanks
Burke
boostedb18kid
Feb 11, 2008 12:22 PM
teddy_dc2
Mar 30, 2007 09:51 AM
X2BOARD
Dec 3, 2004 02:07 AM
playboyace35
10
May 17, 2004 09:02 AM
95c1v1cs1
May 7, 2003 10:14 PM
