Brake light shortage
Old Dec 7, 2003 | 06:19 PM
HybriDNA's Avatar
Default Brake light shortage
I have a problem. everytime i hit my brake pedal my brake light fuse breaks. Would that be because i have a bad ground or because the solenoid on the pedal is bad? i don't understand how all of sudden it would start f'n up. My taillights work tho....could some help me?
Old Dec 7, 2003 | 07:00 PM
CleenSi
Guest
Posts: n/a
Default Re: Brake light shortage (HybriDNA)
i dont know the answer to this, but honestly, ide check all wiring for fraying. but nothing is frayed/dismantled, then **** i deno....try replacing it all.
Old Dec 7, 2003 | 07:20 PM
HONDADNA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybriDNA &raquo;</TD></TR><TR><TD CLASS="quote">I have a problem. everytime i hit my brake pedal my brake light fuse breaks. Would that be because i have a bad ground or because the solenoid on the pedal is bad? i don't understand how all of sudden it would start f'n up. My taillights work tho....could some help me?</TD></TR></TABLE>
Check your brake tail light bulbs for problems. However, I would disconnect the connector at the brake light. Then replace the fuse and depress the brake pedal check if the fuse blowned again. if so, you problem is between the brake switch to brake light connector.
Old Dec 15, 2003 | 08:43 PM
CleenSi
Guest
Posts: n/a
Default Re: Brake light shortage (HONDADNA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDADNA &raquo;</TD></TR><TR><TD CLASS="quote">
Check your brake tail light bulbs for problems. However, I would disconnect the connector at the brake light. Then replace the fuse and depress the brake pedal check if the fuse blowned again. if so, you problem is between the brake switch to brake light connector.</TD></TR></TABLE>
Old Dec 16, 2003 | 08:18 AM
HybriDNA's Avatar
Default Re: Brake light shortage (CleenSi)
I disconnected the brake wiring harness completely from the fuse box and just had the harness from the brake solenoid on the pedal to the fuse box in the engine bay and it would still blow the fuse!!! WTF. So i used a different cabin harness and it still did the same thing! HELP!
prelude_93vtec
Nov 26, 2007 01:57 PM
tai....
Apr 30, 2007 07:47 PM
crxklrlude
May 14, 2006 02:34 AM
Bishop Don Shizzle
Jan 2, 2004 06:23 PM
preluder
Dec 27, 2002 04:35 PM
