Cold Start Problem
Old Feb 11, 2003 | 04:34 PM
Sticky Tires's Avatar
* B A N N E D *
Default Cold Start Problem
it's been so cold my lude needed a jump start to get it going. i notice the first time it died, it still had power...everything worked.
yesterday i went to start it and realized that there was no power at all. so i jump started it and it started.
today i go to start it again and same thing. the battery is 3 years old. should i go get a battery with better cold crank starting? or is it normal because of the frigid weather?
p.s. i did a search and no one had the same problem so i created this topic.
Old Feb 11, 2003 | 05:02 PM
vtecfiendsh's Avatar
Default Re: Cold Start Problem (StickyTires)
sounds like you just have a bad battery in general... cause you are having to jump it, and then the car is running off the power from the alternator cause the battery probably isnt holding a charge.
Old Feb 11, 2003 | 05:09 PM
* B A N N E D *
Default Re: Cold Start Problem (vtecfiendsh)
yeah i think it's because it ain't a daily driver. i haven't drove it since winter started. that probably why the batt. ain't holding the charge. i was wondering if it was normal, if not i'll get a better cranking battery this summer.
Old Feb 11, 2003 | 08:41 PM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
3 years is a pretty long time to have a battery, i'd get a new one if i was you. It should remedy your problem.
Old Feb 12, 2003 | 01:18 AM
* B A N N E D *
Default Re: Cold Start Problem (PreIudeSI)
thanks
specbb6
Honda Civic (2006 - 2015)
Jun 24, 2012 03:07 PM
josephshark
Mar 29, 2009 07:44 PM
dvlsfan30
Oct 21, 2008 05:09 AM
rawsx
Mar 10, 2008 10:41 AM
Tru
Apr 11, 2005 07:10 PM
