Weird CEL
Old Mar 23, 2008 | 02:00 PM
Scott (T.O.A)'s Avatar
Default Weird CEL
ive just finished my obd1 b16a2 swap into what was a EG SI.
when im driving over 60mph ish i often get a constant CEL. but when i turn the ignition off to check the code the cel has gone!?
cutting the ignition while the car is moving and then turning it back on removes the CEL for a few minuites but it then comes back?
anyone got any ideas on what this is or how i can diagnose it?
Old Mar 23, 2008 | 02:23 PM
Garage 808 Hatch's Avatar
Default Re: Weird CEL (Scott (T.O.A))
dont shut the car off, jump the harness while its running
Old Mar 23, 2008 | 02:43 PM
And that should give me the code?
was i meant to wire up the knock sensor when i did the swap? or does the SI harness allready have it done? because i didnt wire it up, could that be it?
Modified by Scott (T.O.A) at 5:48 PM 3/23/2008
Old Mar 23, 2008 | 04:58 PM
what ecu? if its a p30, ya, you should have a knock sensor, but if its a p28 no
B16'D DA9
Jun 17, 2016 11:41 PM
FOMULA91
Aug 25, 2013 04:17 PM
flatblack-h22
Sep 3, 2007 08:55 PM
92civeg
Dec 21, 2003 03:28 PM
